For all who want to make their own mold...
RE: For all who want to make their own mold...
Ok - So hull #1 is a test run. [:'(] Way too thin. Way too flimsy. Thinking double the glass on #2. It all came out ok but just too thin. The variation in gelcoat thickness did not help the finish consistency but as far as using a brush - it looks fine from the outside - just not the ideal technique.. I see a compressor and spray gun in my future.
AB, CANADA
Justaddwata, 10 oz cloth with an ideal ratio of 50/50 resin to glass will yield a thickness of .017 inches per ply. Many of the light weight boats use a single thickness of 1 1/2 oz mat with a 30/70 glass to resin ratio (mat has a higher resin content ratio when done). This gives a thickness of .045 inches for one layer.
In my 72 inch boat I used a layer of 1 1/2 oz (.045"), a layer of 3/4 oz (.023") then one layer of what is probably 7 oz cloth (.013") for a total thicknes of .081". I like one layer of 1 1/2 oz and one layer of 3/4 oz mat on 47" to 54" boats. The cloth you are using is stronger than mat if you get it to the same thicknes.
Your 10 oz cloth will weigh .14 lbs per square foot wetted out at 50/50 ratio per layer. You can use this number to reverse engeneer how thick to make your boat by weighing one already done.
You can add tint to the resin to match the gel coat (or close) and you won't be able to see through the gel coats thin spots in the sun or strong light. It makes it harder to see bubbles in the glass.
Keep going, it is good to know I am not the only one trying to make fiberglass stuff. Models are much harder to get right comparred to bigger boats.
JIM
JIM
