wrap-to-center header / pipe combo wanted
1 Post
I'm looking for a steel wrap-to-center header and pipe setup for my stryker cat (as shown in the sample photo) for a zenoah 260. Any info on manufacturers or where they are currently available would be appreciated.
Banned
GA
RE: wrap-to-center header / pipe combo wanted
Hanson doesnt make any steel pipes as far as i know.
If you are set on a WTC steel pipe... the QD pipe would be your best bet.
http://www.quickdrawengines.com
The wtc pipe in that pic is the "OLD Style" Q/D pipe. They weigh a ton! If you want a new wtc Q/D pipe be prepared to spend $200.00+ for it! The aluminum wtc pipe setups such as the BH Hanson are worthless in a perrformance aspect. The wtc header pipe makes them too long for the pipe to work effiecntly. Your better off using a 100* pipe setup. Brian
Hi i8tweety, that looks like a one piece job. Have a look at this one. I got one but have not run it yet.
Steve.
http://www.rcjets.com.au/rcjets_cata...roducts_id=256
Steve.
My Feedback: (21)
QUICKDRAW WTC PIPES
These pipes are very lightweight (12 ounces) and made of
steel, therefore they have excellent resonance. They feature a
tapered head pipe and a flexible coupling that virtually
eliminates pipe cracking. This coupling also makes it
extremely easy to adjust pipe length. They fit Quickdraws or
Zenoahs. They come in 90, 100, or 106 degrees, wrap to
center (WTC) or Deep Vee. All these pipes perform
identically, there is no loss or change in performance between
the different routing configurations.
( taken from the QD site : http://www.quickdrawengines.com/sample_41Y/Page_40.html )
