RIO 51 After Exhaust Repair w/new rudder
Here she is with a speed master rudder with dual pick ups. So there are 3 total water pick ups. The stock one goes to the piston. Then from the rudder to header, then from rudder to pipe. I re-welded the header and can't wait for her to be back in the water. Also added some nice vinyl stickers.
RE: RIO 51 After Exhaust Repair w/new rudder
I just put bigger lines and a bigger waterpickup and i put a smaller line at the exit to slow down the flow.........
Hey Mr.mauian, I noticed in the 4th pic the bottom cooling hoses in the header cooler are just looped together??? i may be wrong but it should be like the one in tundas pic.
Steve
Steve
ORIGINAL: STEVE MARSHALL
Steve
Steve
thanx for noticing it tho...lol.
AB, CANADA
Run the water line from the cooling cap to the lower outlet of the header cooler and then out from the top... this will help circulation around the o-rings.
HI
ORIGINAL: edmkills
HI
ORIGINAL: firelite_marine
...??? gas lines as water lines? never seen that before. does it help with the high temp at all? looks good
Gas lines like Tygon are typically made of PVC plastic and want take much heat before they melt, be careful so they dont get soft and fall of. I would use silicone lines for cooling, they dont like oil and gasoline, but atleast they wont melt.
ORIGINAL: RhesusMinus
