50" Deep V PLUG Build & Fiberglass Mold Construction
#76
DE
RE: 50" Project PLUG build & Fiberglass Molding
Before I begin installing the next layer, I'll have to remove all the "loose" strands of fiber and scuff the surface so nothing holds up the next layer creating impossible bubbles or makes adhesion an issue.
#77
As a future reference you should have used tissue glass as first layer on mold it will stop the chance of getting print thru on your mold
if you do get print thru which is a grainy imprint of the matt showing thru mold you can wet an dry it out of the mold surface
You doing ok for fibreglass newbie
Also try an make mold approx 8mm to 10mm in total allow at least 72 hours between each layer this will give you a straight strong mold that will last you years
#78
DE
Thanks! "Mold newbie", I suppose....have made a few small ones for airplane parts in the past, but nothing like this boat. May take the next one I make and take it to the fiberglass repair shop down teh road....can we say...CHOPPER GUN! That would speed things up.
Been fun, just taking my time.
#79
Looking good mate this is a good thread and should help me when i decide to make a mould,been thinking about it for a while now so thanks for the inspiration and keep the info coming.
Mart
Mart
#80
HI
Now do a 60inch cat when ya done with this one. Oh and I want to be the first to be on the list for the cat......lol.
#81
DE
Thanks Mart, i appreciate the comments.
Mauian, I'm definately wanting to do a cat sometime.
Just opened a coffee store today so this may slow down a little...but not stop! Wife is hating how the garage smells!
#83
DE
Well.....I mentioned earlier in this thread that I started a new business last week. Been extremely busy with that. Working 16 hrs lately and this project is sitting as I left it 2 weeks ago. Really a shame seeing this ready to work on as I walk by it each day. Wife wants the garage back, so I think it may not be much longer till I get back on it!
#84
WY
Hi Buddy I want to start to do my own Cat 55 I have some ideias I will try to post then here as soon I start, so far your project look very good
#85
DE
Thanks for the compliments....still very busy with the coffee shop just opening, but I'll bet back on it very shortly. Hate seeing something sitting waiting to complete and don't have the time time to do it.
#86
HI
ORIGINAL: Dreamin Hemi
#87
DE
Means I crash hard each night as I come off my caffeine high.[&:] But on another note, spent a couple hours sanding and grinding on the hull in preparation for the next several layers of glass! I want the students to get working on a glass boat before school gets out for the summer!
#88
DE
OK...been busy adding layers upon layers of 3 oz glass. 6 layers total in this lower hull mold. Once it cured for 48 hours after the last layer, I added permanant stands to keep things upright and easy to work around.
The mold was trimmed and wood wedges were stuck in between the plug and mold to open things up a little. Added a bit of water and within seconds, the plug literally slid out. Minor wetsanding/polishing and this will be ready for use!
#89
DE
Total thickness is between 8-10mm
The green liquid is the partall liner that disolves immediately when wet...another good reason to use the right stuff!
#92
Looks vary good Dreamin Hemi I have been following this from the start, I am going to try this on a cat when I get a plug made. Keep up the good work. And good luck on the new coffee shop, Man I love coffee.
Harold
Harold
#93
DE
Thanks for the compliments...if anybody is thinking of doing this, be prepared to spend lots of time...easy work, but very tedious,.
Oh yeah, no "paint through" at all. All the prep on making the plug as close to perfect as I could paid off. No fiberglass patterns anywhere, just a smooth glossy surface. Will hopefully get the deck shaped this afternoon and start glassing before the weekend. Just received 2 orders for glass hulls after my neighbors finally saw it come out!
#94
Looks great mate a job well done,just shows what some effort can produce and to say this is the first time you have done it speaks volumes for your patience not to mention skill keep up the great work and good luck with both your new ventures (coffee shop owner and master boat builder ) .
Mart
Mart
#97
DE
ORIGINAL: martno1fan
Mart
Mart
Working on the shape of the top hull...coming out great...taking pictures as I'm going along and will post tonight. Hardly recognize this as the "Doug" plan anymore.
#99
DE
I HATE YOU ,only joking [)] ,well ive been busy too .
[link]http://www.rcuniverse.com/forum/m_7279351/mpage_7/tm.htm[/link]
#100
DE
Used florist foam to mold the shape of the hull I wanted after I set shape holding ribs in place. Gradually tapered, should give this model a nice rounded, but hot too round look.
