Another Falcon build
RE: Another Falcon build
hey mate yeah got a 1/4 scale jet boat im working on at the moment with a 3 stage jet unit going to run a blata clone engine will be starting a build on the fourm when i get some
VT
dude, awsome
I've always been a fan of jet drives, the ability to travel at a high rate of speed in relatively shallow water, or go upstream through the rapids is just awsome.
Isn't there a huge race circuit swash drives down under? I'll be checking out your build for sure.
not sure about racing maybe in oz ...... and swash drive arnt making there jet drive any more so not realy sure ... im flat out at work at the moment will get on to it when things slow down a bit ...
they're fun to watch, that's for sure. when they make a wrong turn & roll up the bank it can get exciting. they run in very shallow water too.
hey like what you are doing with the falcon cat.. just picked 1 up and was planning to swap out a aqua craft V24 fuji imvac motor . I'm unable to put the canopy on with out it hitting the top of the motor. curious if have fitted a motor yet or anyone else reading this? what motor mounts work . or are you going big nitro
VT
As of right now I'm planning on a Whh m5 that I was using in one of my other woody builds with a 105 deg header, looks like it'll fit I still need to pick up the exaust and collet so I can pull the clutch of it before I put my stuffing tube in. From what I under stand don't waste your time with the fuji unless it's all you have or can afford even a stock zen should push this hull in 50's. My advice is keep reading all of the build threads and see what other people do aswell. Ron Olson has a few pics of his in one of the other threads aswell as a few other guys. I do like your thinking of a big nitro it would be easier to fit and man talk about boot and scoot.
THANK YOU...YES I WILL SPEND SOME TIME READING THE THREADS.. ARE YOU IN MICHIGAN? I KNOW SOMEONE IS... I WILL GO THE GAS ROUTE.. MY FRIEND SUGGESTED DUAL NITRO. WITH STINGERS. MAYBE NEXT BUILD.. FOR THE PRICE OF THAT HULL THAT WILL BE EASY...I'LL HAVE TO PUT THE FUJI IN MY OLD V HULL FOR MY SON.. WILL KEEP WATCHING THE THREADS. I NEED TO LEARN WHERE TO PUT THE HOLE HOW FIGURE THAT OUT ETC.. BEST WAY TO SEAL THE HULL. I USED TO ONLY LOVE THE LAND VEHICLES.... NOT ANY MORE..
VT
Well it's been awhile sence I've work on my pickle,[X(] come on get your mind out of the gutter. I had some time today so I got my rudder,strut, and cowl latches done. The engine, radio box and fuel tanks are just sitting there for now still need to find my center of gravity
