Looking for a nice boat!
AB, CANADA
RE: Looking for a nice boat!
Stride what are you looking for in a boat? play (rough water or not) , race, or play with the intentions of upgrading to race?
Ok i think i found the hull i want Its the Lazer 45 from AC boats.
Is that a good choice? And also ive never seen pictures with its top on, does it come with one?
There is some great video of one of thoes running through some rough I will put it at the top for you.I dont have one but if I buy another mono it will be one of thoes.I am pretty sure they do have a hatch.
Jake
Jake
Banned
not every mono uses a cowl jake, check this out from Insane, it's a trim tab less mono.
http://www.insaneboats.com/index.php...0092bf062920bd
#31
AB, CANADA
Yes they come with a hatch and the AC boats are top quality check out the link I posted earlier. Are you going to be using stock power? If so the Razor may be a better choice, it will run into the 50's withy stock power when set up right. Drop a full mod in the Razor and its a missle and still handles good. I have some info on both as far as recommended hardware and set up and the hulls will come with all the info you need if you order one. Heres the email for a US distributer he is the man when it comes to setting up these boats his name is Dom. [email protected]
#32
ORIGINAL: edmkills
#37
AB, CANADA
Hes a moderator on Jims rc boat dock and the guy Andy at AC boats uses to test all his stuff...
(Link to competing forum removed)
#38
AB, CANADA
Sorry I forgot to add he has a post on there in the manufacturers section that you can order off of and ask him some questions.
#40
AB, CANADA
The link I posted for need for speed has what your looking for. Carmens pipes are top notch and produce great power. I currently run a 2" band CC racing aluminum pipe but wouldn't hesitate to swap for a NFS pipe. Both places have complete set ups. I use a 2" off set header. I can take some pics of my Razor if you like so you can see what it looks like.
#41
http://www.needforspeedhobbies.com/z...etunepipes.htm
For the first pipe, if you get the 2inch version complete system that comes with everything for the pipes, so you just put everything together and you have a full exhaust system that you screw onto your zeanoh? right?
#43
ORIGINAL: JakeDW
The 185 price is the whole system pipe header and water cooled flange then yes you bolt it to the motor.
Jake
Jake
#44
If it sticks out the over the top of the hull you will need a pipe tansom mount if it goes through the hull they have alum sleaves they run through.But that is the complete pipe system.
Jake
#47
Ok, and as for the Rudder, any recommendations?
I found this one, but im not sure if it is long enough(away from the boat)
http://www.topsecretboats.com/inc/sdetail/195
but i want these 2 water pickups for the engine, and exhaust.
