Donation to the lake gods
CO
Somehow managed to do this without hitting anything in the water (rudder and hull bottom don't show any signs of impacting anything). This prop had maybe 15-20 runs on it. It is a "cast" AL prop and was balanced correctly. Anyone ever seen this or had problems with the cast AL props that are now available from some vendors? In the last pic you can see what looks to be another crack forming to the right and below of the "75" stamp. Boat was running awesome prior to this letting loose with a BANG! [X(] Just glad it happened out on the water and not running next to me on the shore [X(] Bad prop/bad luck? or something more sinister like a driveline vibration problem?
MKM
MKM
CO
RE: Donation to the lake gods
The rudder dosen't have even the slightest ding or mark on it, neither does the running surface of the hull. The metal grain does look horrible in person. Didn't want to name any names about where it was from Thought I'd try one for the heck of it, seemed to hold up fine with a stock engine, but apparently didn't fare as well with the power output of a modded one. Any futher comments/flames welcome
My Feedback: (27)
Seeing how the cracks seem to stem from the hub....is it possibly that it's a cheap/soft casting combined with too much torque on the prop nut leading to the premature failure?
Just a thought,
Neo
Just a thought,
Neo
Even the high $$$ props have their days.[&o] Get another one, but get it from a reputable prop guy like Dasboata. It will be balanced and polished and sharp! That prop looks like it came out of the package with nothing ever done to it.[] It was probably out of balance, but you can not predict what your going to hit below the water surface that will take out the best props. Brian
CO
Thanks for the replys, seems im not alone with the issues with the AL props. Lesson learned, I'll stay away from them. I think my next gas boat related purchases need to be some decent props, from a prop guy that knows which end is up Because that certainly isn't me at this point!
MKM
MKM
They're not the only ones that they can hapen to as even good brand-name props have been known to throw a blade. Most come from overthinning a prop than not heat-treating them aftewards. One brand, it may have been ABC but don't hold me to it, had a bad batch of gas boat props that was in one size only that they replaced free of charge.
The scary thing about this is that the prop could have just as easily broken while trying to start the engine and done some personal injury.
To me, in the shot at the beiginning I'd say that the aluminum may not have been in a fully molten state when it was poured/injected into the mold. If you got it from Tony, you might want to let him know.
That prop did look bad quality ,that said ive been using one in a boat for a year (ali prop)with stock zen and no probs so far.I think theyre ok for the money but i dont think id run one on a full mod ,i tried modding one and snapped the blade so i know how easy they can be to damage .
Mart
Mart
