Zenoah 26 Hard to pull
My Feedback: (59)
IN
IM REALY new to gas boating. I bought a boat with A Zenoah 26. It pulls realy hard when I try to start it. Do they make a compreson release for these engines? It Fired 1 time with pulling it about 20 times . Its hard to hold the boat and pull the stater rope. ANY help I would be greatful.
Thanks for you time.
RE: Zenoah 26 Hard to pull
Your engine is possibly flooded withfuel.
-Remove the plug and hold the boat inverted then tug on the pull start cord about 5 times then re-install the plug tight but do not over tighten.
-Close the choke and prime the carb once.
-Pull the starter cord a couple of times until you hear a pop.
-Open the choke and pull the pull starter until the engine runs.
Your engine should run if the needles are set right.
TN
You can loosen the spark plug just enough to lower the compression to get it cranked and then stop the engine, tighten the plug and restart.
Something's up if your pulling the rope 20 times to start it. Like viper said it's probably flooded, but also make sure the butterfly is open. I had a horrible time starting an engine once only to realize I had my radio throttle set up wrong and it was killing the engine[:@]
When I start my engines, I choke mine by putting my thumb over the carb and pull the rope a couple times til the engine pops. It should then fire on the 2nd or 3rd pull.
You'll get it, we've all been there
My Feedback: (59)
IN
Tanks all for the help. I findley got it started. My shop is cold so the engine was cold about 25 deg. I warned up the shop and warned up the head with my heat gun and it started right up. So this summer it should start right I HOPE LOL. Again THANKS
ORIGINAL: nieto1124
some pics would help. they also make a pull starter taht stores energy and then releases which might work for ya.
http://69.49.183.35/SearchResults.as...=24&Search.y=7
they make a huge difference in starting well worth doing for the price you pay
cheers craig
