TURBINE!!!!
TURBINE!!!!
Hey guys,i have seen a few videos of r/c boats with turbine motors...do you have any idea of how fast they really run? My father has a few r/c jets with turbines and the are FAST...200+mph!!!
MN
RE: TURBINE!!!!
I,ve been looking and have not been able to find any indepth info on these. how are they rated for power? what kind of speeds could you expect in a 60-70" cat w/twins. jason
FL
RE: TURBINE!!!!
If I remember correctly the jetcat or WREN turbines are around 10hp and weigh around 6 pounds, and a bargain price of $4000. This is just from memory though
RE: TURBINE!!!!
Jet-cat turbines vary in thrust from 3lbs to almost 40lbs. Spool up to 165 thousand rpms. You would need a two stage and a large gear reduction. To get it down to the 20 grand needed. Check out jetcat web site tons of info. Mostly helicopter info. But its my understanding there working on a gas boat gear box and turbine.
FL
RE: TURBINE!!!!
ORIGINAL: Jamming
Jetcats come with gear reduction, I believe the output is from 19,000 to 35,000. in the pic the purple and gray housing is the gear case (water cooled).
USA site less info [link=http://www.sitewavesstores.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=JetCat&Product_Code=SPM-5]http://www.sitewavesstores.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=JetCat&Product_Code=SPM-5[/link]
German Site [link=http://www.jetcat.de/jetcatturbinen/0493fc9a480b39a01.htm]http://www.jetcat.de/jetcatturbinen/0493fc9a480b39a01.htm [/link]
Technical data:
Output: 8 KW (2 - Turbine Shaft)
Weight: 2930g
Dimensions: length approx 375mm, width approx 100mm, height 160mm, approx 83mm diameter turbine
Peripherals Weight: 650g (ECU, valves, gas tanks, battery, cables and hoses)
Speed: 50000 - 175000 1/min.
Output speed: 19000 - 35000 1/min. (Depending on the gear reduction, three are possible)
Exhaust temperature: 480 - 730 ° C
Fuel consumption: approx 260 260 ml/min (Vollast) ml / min (full load)
Fuel: Jet A1 kerosene, petroleum
Lubrication: approximately 5% vollsynth. 5% vollsynth. Turbinenöl im Kraftstoff Turbine fuel
Maintenance interval: 50 hours
