OUTBOARD DRIVE home built
ON, CANADA
just bought a emco mill lathe, for the price of a mh$ s6 stern drive. ive made other outboard drives for my tunnel boat, but the cable style didn,t last, worked good & fast, but liked to eat cables, so i made 1 with a 90 degree air die grinder , worked ok , but there under drivin, by about 20 percent, so i have new plan, buy mill lathe , use 18 dollar air die grinder gears and make my own gear drivin outboard lower leg.total cost so far 518.00 bucks , got all tooling with the mill lathe used, check it out. also switched gears, now its over drivin.
ON, CANADA
RE: OUTBOARD DRIVE home built
thanx guys i will be keeping every one up to date for sure,be trying to buy a new tunnel hull from aeromarine ,preditor large scale , but they don,t list it, but ive seen one from fine design, any how,as far as selling them, that will depend on testing soon i hope,i will just glass a new hull myself next week or so.
ON, CANADA
hi mat, yea i hope the gears do ok ,the only problem switching them is the mesh is know backwords, ive bench tested the drive, it seems good at 18000 rpm, i used another die grinder for that, at 100 psi,thats what its rated for 18000 rpm,by rights the prop shoud of been spinning 20 percent faster, now of corse thats with no load,every thing seems good though, no metal in the oil , afterwords, i run it on and off for about 10 minates , i have a question for you mat, how big are the gears in a mhz sterndrive, just wondering, the die grinder gears are 3/4 di & 1/2 di. well thats all for now.
ON, CANADA
o by the way guys i also found another set of gears with nice bearings in a 90 dagree dremel head but there equal size, still really nice small set though, might try them on another one, just thought i would let use all know, o yea there more money too, about 50.00 bucks here at the home depo . chat later
Great job!!!....can only add to the kudos....Looking ahead, I think you will have a big problem turning a gas OB hull with the short skeg....one at least twice as long might do the job...check out the skeg on F. Lowe's Outlaw lower dr. and the Gmorty (?)..made in Australia...even the lower units used on the old AMPS OBs made for nitro engines had their problems..solved by the way, by power trim off a third channel to tuck the engine under on turns...keep at it, we need gas OB inovators and boaters!!!
JS
JS
ON, CANADA
thanx for the input jay, i will try that on the next one i built, after testing this one,the reason its short , the piece of alluminum was short,iuse what i get for free, should be fine with 2 1/4 scale servos ,heres my first &second drives, 1 cable & 1 die grinder
OK
Nice work Sharpy. Brings back memories of my CNC Lathe days!
I would not trust the 90 degree Dremel gears as they barely hold up on a Dremel. I have already busted a set I bought 2 weeks ago and used 4 times. Not very durable from my experience.
Cheers,
John
Cheers,
John
Sorry for the delay - let me track down a few old gears I have to give you an idea of size.
Another option may be a high end right angle air ratchet/nut runner (basically the same as a die grinder but more torque and less RPM). I will take pics of mine along with gears tomorrow
Hard to beat the price of a discount die grinder though - now if you could find someone who sells the heads you would be all set!!!
ON, CANADA
hi mat look farward too seeing the gears from one of your units , can,t wait, i have some new pix of some more parts ive been making for the transom part of the outboard, probably post them friday, been busy airbrushing harley parts
ON, CANADA
here,s some more pix of the project , still got more milling to do,making all the parts smaller and lighter,im down to 1 3/4 lbs, i think i can get it even lighter by milling more off the parts,might change the transom set up,
I don't think weight should be and issue. Run the thing lets see what it does. That's the important point. Looks good though got me machining and trying new ideas.
Cobus
Cobus
ON, CANADA
hi all, seems every one including myself want to know if this thing is going to work,well im just buting it back together on a jig to take to the lake this weekend to try it,i will do some extream running of it,and yes i will take video,hope the weather is good this weekend fore boating also,last week was windy as heck, my buddy,s both run bud hydro,s , they wimpped out all day,im still running my moddifyedtunnel with in board,loves the choppy water, any how here,s couple more pix.
