"block isolator"???
RE: "block isolator"???
What he said. It helps to keep the heat from the block affecting the gas. Some people are also using them now as a tuning tool finding the the thickness of the block can make a difference in how well the engine runs.
Ever wonder why Pro Stock Drag racers run tall plenum chambers on their cars?
TN
You don't have to have the aluminum aftermarket ones, but if the stock isolator block warps it can wreck havok with tuning the engine. I have never used one but I have heard some people swear by them.
FL
Is there any that you would recommend? The CC iso block looks nice, just a little pricey to throw away $45 on something not worth it. But i am all to it, if it will make the boat 1mph faster!!! hahahahah
I used the stock plastic one, I found it great for ease of modification. I had to drill it out nearly double the size, match port it to the head and fill and re-drill the crank presure hole to suit the new bigger carby. I know this can be done with an alloy part but I loved how easy the plastic was to work with....
Cheers, Chris
Cheers, Chris
