prop rotation
prop rotation
if i do 1 engine,conected to a gearbox,so i can drive 2 props from 1 engine.it will be on a 72" mono.must the props be of different rotations or can do them rotating in the same direction ? thanks
RE: prop rotation
They can be but it's my understanding that you want them turning opposite directions. This would reduce prop walk and make the boat run straight without the normal tendency to turn left.
PA
RE: prop rotation
You can run them in the same way but you will have issues with turning and chine walk.
For safety I would run the opposite like the Traxxas Villian is.
RE: prop rotation
Most gearboxes you can buy have counter-rotation.
You can switch between in or outwards rotation.
Some gearboxes have a 'overdrive' ... that's not for Zenoah's but for Pollini's and Blatta's.
My buddy's [link=http://www.wd200-modellbau.de/?Getriebe%2FGearbox]Werner[/link] and [link=http://www.matho-powertrain.de/webkatalog.htm]Thomas[/link] are making/selling some gearboxes .... if you want help .. just ask.
RE: prop rotation
hi guys,ok from what you told me, i must have em counter rotating.now can anybody send me designs so i can have it custom built from a friend as i would like to keep the cost low thanks
RE: prop rotation
You will need 4 same size spur-gears ... induction hardened @ 38€ a piece.
That's 152€ for the gears only ... Casing : count for 20 > 30 € for 7075 bar stock ,
add 8 x C3/RS2 bearings @ 15€ (120)
then you have a total of 250 > 300€ on materials as a private person.
Gearbox is not even made than .
So the price of commercially available gearboxes is not that bad.
Home-made foolproof gearbox could look like this :
RE: prop rotation
Keep an eye out for this one from this guy its the cheapest ive seen and will stand upto 12 hp .Maybe drop him an email he makes them although he has the cases made in russia i believe.
Mart
[link]http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=130321132430&ssPageName=ADME:X:RTQ:GB:1123[/link]
Mart
RE: prop rotation
ORIGINAL: loppol60
but cant i do the props turning the same direction and then just turn the rudder or mount the stinger slightly tho the right?
Mart
RE: prop rotation
ORIGINAL: mart
Ha ha razzfazz ... So it seems Paul F isn't dead yet ?
RE: prop rotation
ORIGINAL: martno1fan
Mart
Mart
Just yanking your chain
