If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 7 of 7
  1. #1
    Join Date
    Feb 2007
    Wichita, KS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Help with MHZ Counter Rotating Gear Box
    Hello All!!!
    I need a little help. I am in need to split and rebuild the gear box as the bearing seals went south and leaked some gear lube...gears and case are fine but bearing seals are shot...might as well replace with the good stuff while it is split.
    MANY months ago I stumbled across a thread on this on either Jims or RCU and I cannot find it for the life of me. It had the Boca Bearing Part numbers and a real quick How-To on getting it split and put back to gether (pictures and all).
    ANY help here will be GREATLY appreciated!!!!
    Thanks in advance,
    Trey
  2. #2
    Moderator Justaddwata's Avatar
    Join Date
    Feb 2005
    RI-USA, RI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Help with MHZ Counter Rotating Gear Box
    Hi Trey,
    Think I know the post your referring to. It was a build of a Jolly Motors cat and believe he rebuilt the gearbox with ceramic bearings. Believe the thread was on Jims. Will see what I can turn up. I could use the part #'s too.
    One of the better gas boat picture sites - http://imageevent.com/justaddwata
  3. #3
    Join Date
    Feb 2005
    RI-USA, RI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I received the brg's and they look good. There are three different brg's in the gear box. Six for the small gears and six for the big gears. the input and output shaft brg's are sealed. They also supporting Collet's and cables. So I bought the best brg's they had to those three brg's. Before i took it a part i spun the gear box with a high speed die grinder and it had some vibration at high speed. That is why i replaced the brg's. The tolerances on the new ceramic brg's are about the best money can buy. So when I get it back together I'll let yeah know if the vibration is gone. I bet it is, just checking the play in them you can tell alot of difference. More latter.
    Part# 3-smr607c-2rs#3
    6-smr697c-yzz#5
    3-smr607c-ycc#5
    Jims member: TAPruitt post 06-25-2007, 08:53 PM (Page 9)
  4. #4
    Join Date
    Aug 2008
    Midland, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    No conclusion on the thread. Did he ever get it running
  5. #5
    Join Date
    Feb 2005
    RI-USA, RI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    have not seen her in action anywhere - he is no longer a member there (not by that screen name anyway) so hard to find out.
  6. #6
    Join Date
    Feb 2007
    Wichita, KS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    YO! Thanks for the info, Matt!
    That is exactly what I needed! I am not sure if he had her running either??? Never saw an update anywhere. I sure hope his son made it through and back in one peice after his gracious service to our wonderful country!
  7. #7
    Join Date
    Feb 2007
    Wichita, KS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Update on the gear box an dbearings:
    I emailed Boca and they were VERY helpful. The original bearing numbers posted above were total $205...Boca helped me chose a diffreent bearing setup that will outperform the ones above AND saved me $50 in the process. Great service. Bearings are "in the mail."
    part numbers and prices listed below:
    6 pieces SMR607C-2YS @ $13.95 each = $83.70 &
    6 pieces SMR697C-2YS @ $11.95 each = $71.70.
    Total = $154.40. Shipping is by UPS and free.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
