Share pics of your first gas boat
My Feedback: (14)
RE: Share pics of your first gas boat
heres my first. first boat ! first paint job! still original as i built here in the early 80's. Mac watercooled 22cc motor with AMP's drive on it. I still have this boat. runs like a champ paint still in great shape. not the fastest on the lake thats for sure. but very dependable.
MI
after a couple electrics, i graduated. here's a pic of my Rio next to my new project build. i started with a scratch and dent from tower hobbies and rigged in engine and hardware. it ended up better than i expected and i definately learned.
what it looks like on the inside, semi custom header and all
#37
any recommendations would be helpful
thank you
john
AMXer (02-13-2022)
#38
I am a newby going to build my first Deep vee hull 45.5” x 13.5” x 9”. What to use a homelite 26cc w/clutch. Can you recommend a prop size and pitch, that will get me safely running on calm water pond. I want to use inline shaft holder with prop followed by rudder.
thank you
john
thank you
john
Certainly start a new thread as you get your build started !
AMXer (02-13-2022)
#40
Electrics are increasingly faster out of the box and the number of new boaters looking for an 80+ MPH starter boat is both scary and ever increasing. Gone are the days when experience and years of work were required to earn such speeds.
Dana W (02-23-2022)
#42
Sadly I see a considerable backward step in Gas RC Boats the past few years (in the hobby as a whole). With many European countries and high end builders switching away from Gasoline based power there has been a limited supply of development at best. Inline motors, turbines - are essentially gone from the marketplace regrettably. Maybe there will be some options in the future but I am not overly confident.
When you look at the shelves at the LHS or offerings online, you see few boats and most of the planes are either RTF, ARF or "plug and fly" types, most of the RTF and "plug and fly"types being made of foam. They are serious "money makers" for the manufacturers since they are cheap to make and easily disposable if damaged. Add to that the "self-correcting" electronics, almost anyone can fly them. This falls right into the desires of the "I WANT IT NOW!!!" crowd, since all they have to do is:
- spend some money
- take the plane/boat home
- do some minor assembly
- install batteries
- fly/run until they crash
- REPEAT!!!
