Expresscraft Cheeta Test Run Pic's
NY
Test run went great !
Man it was fun to run a R/C boat again, it's been a while !
First 5 min's I had about 15 people watching me, they loved the boat !
Got the Cheeta in the water ran around slow at first to check water cooling system
I made a few slow passes to check radio trim no adjustments needed ! luck !
Hit the throttle she lifted right on to plane and ran great but was running a little wet ! see pic's
That's ok, a few small adjustments will take care of that !
After 10 min of running I stopped to check things out, every thing was perfect !
Check the GPS 40.6 off the bench settings . Man I'm happy, that was my goal speed .
She has a lot more for sure as it was running very rich, tuned pipe needs to be shortened
and header needs to be cut to correct length.
I need to get a prop as I was using a prop from my cat 7016/3 to big !
Second run
I made a small adjustment to the strut to lift the bow still was running wet but better.
I ran for 1/2 hour and only used 1/2 of the tank of fuel . Next time I won't fill the tank.
After running I checked the GPS 42.8 before I could not take a pic of the GPS the battery's died.
I'm very happy with this boat I think with time I will get it in 50 MPH range, better then I wanted !
Now I will go strip her down and paint !
Sorry no video I could not get the camera in video mode !
Steve
Second run
Steve
KS
RE: Expresscraft Cheeta Test Run Pic's
SWEET!!!! Congrats! Sounds like a great first test run...lucky no radio adjustments. I am JEALOUS!
Maybe a 6518-3??? or even a VooDoo XX Tater??? Keep us all posted on the progress and Happy Turkey Day!
NY
Thanks guy's
Very fun build and ran great right off the bench too !
After painting the Cheeta I'm going to get my cat done . That will be a nice build!
I will post pic's of the Cheeta after it's painted .
Steve
Steve
great picts... looks like it was running good fro the first test run !! Good luck with it !!! Thanks for the picts !!!SK.
hey... steve nice run pics.. looks like it goes nice... i saw it when u first starting biulding it u did alot of work to that thing.. please paint it already so we can run!!!!.. <input id="gwProxy" type="hidden"></input><input onclick="jsCall();" id="jsProxy" type="hidden"/>
NY
ORIGINAL: nyvenom30
hey... steve nice run pics.. looks like it goes nice... i saw it when u first starting biulding it u did alot of work to that thing.. please paint it already so we can run!!!!.. <input id=''gwProxy'' type=''hidden''></input><input onclick=''jsCall();'' id=''jsProxy'' type=''hidden''/>
Thanks for the kind words, not that much work. It was a easy build and fun. After paint we need a nice day to run.
Now that you are on RCU you have to post pic's of your boat !
Steve
