hurricane cat 4
hurricane cat 4
hello people....i resently acquired a herzog hurricane cat 4 and have a question.....can i move the offset rudder to the middle of the hull behind the the prop....problem being...at 1/2 speed the boat runs straight...at full speed it wants to turn to the left and i have to trim the rudder to straighten it out.....its just a pain the the azzwhen you trim it for hi speed and let off the gas it wants to turn to the left really bad .......anybody have any ideas on this rudder
thanks for your time
RE: hurricane cat 4
check the location of the strut, is it dead center? it needs to be a little offset towards the strbd side. This will help ot counter react the prop walk.
RE: hurricane cat 4
it is offset..... i want to know if it can be moved to the middle of the hull straight behind the prop with no offset.....
RE: hurricane cat 4
are you asking if the rudder can be moved to the center? yes. If the strut is not in the correct location you will still have the same problem. Did you buy the boat new or used? Are the sponsons true? Does the boat have any twist?
RE: hurricane cat 4
Yes turn fins can cause the trouble seen that many times. But on a cat, turn fin is not needed. There is skegged strut that is made for cats, that has a fin on it. [link=http://www.cc-racingengines.com/index.php?page=shop.product_details&flypage=flypage_images.tpl&product_id=128&category_id=14&option=com_virtuemart&Itemid=53]Skegged Strut[/link]
RE: hurricane cat 4
OK, I see where you threw people off as at first I thought that you were typing about a Catamaran, not a Category 4 hull which I've never heard of it being called that. What you probably have is one of Chris' Hurricanes.
First off, I don't know why you're using a skegged strut on a mono as it shouldn't need one and that might be part of the problem. Usually the problem is the boat wanting to pull to the right. I'd hate to tell you to get out a saw and but the skeg off but that's what you might have to do but wait until someone smarter than me replies.
My only other thoughts would be to see if you have a strong rudder servo and 4-40 rod for linkage, sometimes obvious questions but I gotta ask. A weak servo and 2-56 piano wire can make a boat do strange things.
RE: hurricane cat 4
ORIGINAL: Ron Olson
well thats what was on there when i got it....it was used...i have a stinger setup coming for it as itype this out ...should be here in another couple of days....the rudder setup is from speedmaster...i have a new 1/4 scale hi tec servo and i do have 440 rod,but only side of rudder
RE: hurricane cat 4
Jeff Daft runs Herzog racing Products and would be able to tell you exactly what works on this boat. I've been dealing with Jeff for some time now and he is very good at what he does, and I just realized how he sells his boats. [link=http://www.herzogracing.com/_sgg/m4m1_1.htm]Herzog Racing[/link] Category 1 through 5 is the level of completeness of the boat, if it was a cat IV contact Jeff and ask him for advice.
RE: hurricane cat 4
great news .....i spoke to jeff at herzog and from what i had told him and thefix he came up with was the rudder was put on the transom over 1 inch to far to the rite ...so i took it all apart and filled all the holes with resin and moved it to where it is suppose to be....now i just have to wait for the water to get soft again in april to try it ....hahahaha here are a couple of pic ..in the first pic you can see where the standoff was placed...as per jeffits just to far off
RE: hurricane cat 4
ORIGINAL: Ron Olson
I'm just wondering how the rudder linkage was hooked up being that far over! A rule of thumb that I use is to place the rudder directly behind the stringer, i.e., 5" wide rails, 2-1/2" offset.
thats the same thing jeff had told me..i sure hope it solves the issue
