Speed - RC Gas Boats Discuss gas RC boats right here!
Gas Jet Boaters
Reply
Old 04-14-2010, 10:59 PM
  #251
dicko
dicko's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Gas Jet Boaters
Dana,
You can weld a flat plate to the bottom of the rollcage & drill 2 holes in each plate, then mount some wood to the inside of the chine you can screw it straight to the wood. that way it can be easily removed for maintenance etc. This is the way Craig does/did his on the swashdrive units, & the way I intend to build mine (although I'm planning on using carbon fibre for the rollcage).
dicko is offline
Old 04-14-2010, 11:17 PM
  #252
dicko
dicko's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's a pic with the mount circled in red.
The pic is from the forbidden site.
dicko is offline
Old 04-14-2010, 11:23 PM
  #253
Scott Schneider
Scott Schneider's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: dicko
Header style looks quite familiar, but really loooong IMO
Agree on roll cage mount, needs to be attached to the stringers and not on the hull.
Scott Schneider is offline
Old 04-15-2010, 12:17 AM
  #254
dicko
dicko's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm not sure who's boat that pic is from, Craig has a short header set up similar to the one you have shown, except his goes back across the boat at a 45* angle. I've been looking into the outboard pipe setups as a basis for design for what I want to do. Some of the Baja ones could also be made to fit as well I think. that is a way down the line yet though.
4 weeks & I'll be back in Adelaide with all my tools & my shed. Then the build will begin. I'm looking forward to it.
dicko is offline
Old 04-15-2010, 02:23 AM
  #255
infinityteg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hi guys.
boats looking good Dana.
I mounted another set of stringers along the chine and bolted the cage to that. I also mounted some blocks up at the deck for extra rigidity. before i bolted it to the deck i broke it out of the bottom. it was only 3mm wood glued in so should of been stronger i guess but it hasn't moved a mil since
As for the header im using it is a bh hanson, would be nice to get one a little bit shorter.
first stage of my new roll cage is going together just need to get some more tubing.
Its 3/8" copper tubing that will be silver soldered together
which is this forbidden site that you speak of (just in case im missing out on something) PM me if you have to
cheers
steve
ID:	1418311   Click image for larger version
ID:	1418312   Click image for larger version
infinityteg is offline
Old 04-25-2010, 09:25 PM
  #256
wave waker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
where are the peeps here? it's been so quiet for awhile..
guys, got a question? i'm looking for a jetdrive for a jetski hull measured 40 inches by 15 1/2 inches, i'm planning of using electric motor... any info. is appreciated.
ww
wave waker is offline
Old 04-25-2010, 09:36 PM
  #257
Scott Schneider
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: wave waker
ww
GRAUPNER
Old 04-26-2010, 04:25 AM
  #258
mickieb49
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Correct me if i'm wrong but i think most people play with the jet boats once racing is finished Wavemaker, Graupner (as scott said) or kehlrer may be able to do a unit you wish.
mickieb49 is offline
Old 04-26-2010, 11:22 AM
  #259
Scott Schneider
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: mickieb49
Have taken mine sense finished to a couple races, Run before and after which usually draws a pretty good crowd .... giggles all around with many a clapping hand and odd sounds from the crowd as the boat does it's flips and flat spins.
Waiting on two other guys I race with to get theres built, they too purchased Davette hulls but had to use Graupner drives. The rigging of the engine too pump connection being a trouble spot for them currently.
Old 04-26-2010, 06:34 PM
  #260
HendricX
HendricX's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Scott Schneider
1 Short piece of bar-stock (Ø1/2") threaded M6 > 1/4" ..
1 Short piece of bar-stock (Ø1/2") Flat 8mm > 1/4" ..
Schort piece of 1/4"flexshaft inbetween ... what's so difficult about that ?
OK ... let them buy my engine > jet-pump couplers.
HendricX is offline
Old 04-26-2010, 07:29 PM
  #261
Scott Schneider
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: HendricX
1 Short piece of bar-stock (Ø1/2'') threaded M6 > 1/4'' ..
1 Short piece of bar-stock (Ø1/2'') Flat 8mm > 1/4'' ..
Schort piece of 1/4''flexshaft inbetween ... what's so difficult about that ?
There doing it and not me
Old 04-26-2010, 08:41 PM
  #262
infinityteg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Local company is selling this coupling for quite cheap
http://www1.jaycar.co.nz/productView...T&SUBCATID=726
tap one end for the jetunit and a shaft on the other end.
Old 04-27-2010, 10:51 PM
  #263
wave waker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
any graupner jetdrive distributor here in USA?
or how easy to order from HPM in new zealand to USA?
thanks
ww
Old 04-28-2010, 04:18 AM
  #264
infinityteg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I guess im lucky they are 15min down the road from me.
Kim, Tony and Andrew are great people to deal with and ship all around the world all the time.
I wouldn't hesitate to order from them if i couldnt walk into the shop
cheers
steve
Old 04-28-2010, 04:25 AM
  #265
bentley marshall
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
+1 hpm are great i have bought off them a few times
bentley marshall is offline
Old 04-28-2010, 05:54 AM
  #266
DRAGONFIRE81M
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks
ww
you can get the drives from http://www.hobby-lobby.com/ there loc in nashville tn . but the last cuple i have gotton i have used http://www.cornwallmodelboats.co.uk/...upner_jet.html
what graupner drive are they useing and haveing proplems with a engine to drive link ? is it the 2347 drive ?
DRAGONFIRE81M is offline
Old 05-01-2010, 08:51 AM
  #267
aussier6er
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
guys i am looking at getting a mhz Jet Power 3 Race unit !!
looking to get some of your thoughts and reviews on them before i but it
cheers guys
aussier6er is offline
Old 05-01-2010, 10:21 AM
  #268
wave waker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: aussier6er
cheers guys
what i'm hearing is lots of problem ordering from mhz unless u'll get it from other store...no idea about the product...
Old 05-02-2010, 12:29 AM
  #269
dicko
dicko's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I was Talking to George from Hobby Depot about this unit before I got my Swashdrive unit. They are currently not in production & out of stock. They were going to do another run of them soon if not in the process now. Give him a call & see if he has heard any more details.
dicko is offline
Old 05-03-2010, 03:48 AM
  #270
aussier6er
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks dicko
yeah i placed a order with george on saturday but i havent been advised it they are backordered ??
if so looks like i will be waiting for one !!!
Old 05-03-2010, 01:20 PM
  #271
Dana W
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well finally I've got this boat running . I'm using a dog bone universal joint . We'll see how long this will last . I'll take her out tomorrow morning and test out the KMB pump and keep my eye on the dog bone ). Here is a short video .
http://rcuvideos.com/video/Jet-Sprint-Boat-Running
Dana W is offline
Old 05-03-2010, 05:40 PM
  #272
dicko
dicko's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks dicko
Did you ring George, or order it off his website? Last I spoke to him they were still on backorder.
dicko is offline
Old 05-03-2010, 05:59 PM
  #273
dicko
dicko's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dana,
Looks good, I get to start building mine next week.
I'm not sure about the pump you have, but I know with a Swashdrive unit you must run the pump wet when you test run the engine, otherwise the bushes overheat & wear out. If your pump is a bearing mounted unit you may be OK.
Cheers
Jason
dicko is offline
Old 05-05-2010, 11:48 AM
  #274
Dana W
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yep , it's got a bearing . It didn't seem to hurt it at all running it out of the water .
I took it to the pond today and I have to say I'm very impressed with that KMB pump . It pushed the boat no problem . It was like playing with a jet ski . To take a guess I would say 30 mph easily . I didn't get a video because I was by myself . Now I'll get it ready for a paint job , then we'll get some video .
Dana W is offline
Old 05-08-2010, 02:08 PM
  #275
Dana W
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I ran the little sprint boat pretty hard today to see how the dog bone would hold up under pressure . Well the dog bone universal joint did fine however I sheared the KMB jet pump drive shaft off . The shaft steps down from 1/4" to 5mm . That was the weak spot ( see photo ) Here is a short video of it running . http://rcuvideos.com/video/DaVette-Sprint-Boat . I'll make another boat and go with the Graupner Jet Pump .
Dana W is offline
Reply
Display Modes
