If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 12 of 20 FirstFirst ... 21011121314 ... LastLast
Results 276 to 300 of 485
  1. #276
    Scott Schneider's Avatar
    Join Date
    Feb 2008
    Old Hangtown , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    ORIGINAL: Dana W
    I ran the little sprint boat pretty hard today to see how the dog bone would hold up under pressure . Well the dog bone universal joint did fine however I sheared the KMB jet pump drive shaft off . The shaft steps down from 1/4'' to 5mm . That was the weak spot ( see photo ) Here is a short video of it running . http://rcuvideos.com/video/DaVette-Sprint-Boat . I'll make another boat and go with the Graupner Jet Pump .
    Dana,
    Bummer ... yea a lot of vibration going on at that connection. Unless alignment is dead on and runout dead even you got [:@]
    have a new shaft cut without the step and work on the runout of the dogbone coupler to get it perfect.
    Honestly tho, with the engine in A/V mounts and dog bone couplers needing perfect alignment, really not the ideal connection type IMO.
    Love the Hobby, Hate the Politics .....
    Home of MOTORHEADS RC Racing Engines.
  2. #277
    Join Date
    Oct 2006
    Auckland, NEW ZEALAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    My weekends running was just carnage. took the boat to my auntys place who has a small river running through her property. its about 6-7' wide which is probably not quite enough when your doing 50-60k/hr. After seeing all the real sprint boats, they al get beaten up a bit. The biggest hole has gone right through and it only the pool noodle holding the wood over the hole. and a broken pipe mount
    cheers
    steve
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1434399   Click image for larger version.
ID:	1434400   Click image for larger version.
ID:	1434401   Click image for larger version.
    Infinity RC
    1/4 scale jet boats
  3. #278
    Join Date
    Feb 2008
    Old Hangtown , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    ORIGINAL: infinityteg
    cheers
    steve
    Steve,
    But did you have fun
    See an RCMK in there now for power, how it run for ya ?
  4. #279
    Join Date
    Oct 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    it was a blast. just not long enough.
    the rcmk is great. just that little bit more power than the Zen has made such a difference.
    Infinity RC
    1/4 scale jet boats
  5. #280
    dicko's Avatar
    Join Date
    Feb 2004
    Adelaide, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    I joined the deck to my hull today. It's coming along now. Starting to look like a jetsprint.
    I've got a build thread going over at the Snikwah site.
    http://modeljetboat.com/forum/index.php?topic=14.0
ID:	1434641   Click image for larger version.
ID:	1434642   Click image for larger version.
    The answer is always more power.
  6. #281
    Join Date
    Feb 2008
    Old Hangtown , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    You running the 3 or 5 blade impeller ?
    Work faster, more hours, late nights .... get er done
    Lookin good
  7. #282
    dicko's Avatar
    Join Date
    Feb 2004
    Adelaide, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    I'm limited to the setting time of the resin at the moment. Typically it's our first cold week as winter sets in so the times are a little longer. I need to go buy a heap of parts before I get much further too. I just got a quote from Bruce at Gizmo Motors for a few things I need & once I have the cash I'll fire that order off. I'll have to get Ken at Retallick Engineering to fabricate a nice stainless header for me to fit the boat & also make me a pipe to suit the 29cc head I plan on putting on there. I'll also get him to modify the 29cc head too.
    This is one of 2 builds I am currently working on. I must admit, I'm putting more time into this than the cat. I should probably get onto the cat soon, I plan on racing that in a couple of weeks!
    After i mount the backing plate for the skirt bracket, I might have a go at laying up the carbon for the rollbar. I'll need to make a mold for that though.
  8. #283
    Join Date
    Oct 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    Scott
    I made the mistake of only getting the 5 blade impellor. i wish i had of got both now. but the lil extra torque from the rcmk has made a world of difference.
    Dicko
    Builds looking good. ive saved all the pics for future reference
    I made my cage out carbon. I only done the female mold though. i used 5 layers of carbon uni's. Im not sure on the weight of the fabric now though, it is strong as ever though. i just used some 18mm custom wood screwed into a u shape and car bogged the corners into a nice curve. then used brown packaging tape layed evenly for the molding surface. it wasnt hard to sand the very small ridges the tape overlap left.
    cheers
    steve
    Infinity RC
    1/4 scale jet boats
  9. #284
    dicko's Avatar
    Join Date
    Feb 2004
    Adelaide, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    That's funny, I use packaging tape for a lot of my molds too. The resin just won't stick to it & it's easy to pop parts off!
    I have the rough measurements for Craig's Swashdrive roll bar & will make a similar sized one out of carbon. I found that if you squeeze the excess resin out of the carbon you can get a much stronger laminate. I plan on using the mounting blocks Craig provided with the kit to mount the roll bar to. I will probably only have time to mount the jet unit today & I'll get onto the mold over the weekend.
    Cheers
    Jason
  10. #285
    Join Date
    Jul 2006
    Bend, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    I came up with a solution . With what little drive shaft I had left on the pump I managed to find a round collet with set screws for the 1/4" pump shaft . I put a square drive collet on the engine . I installed a square drive flex shaft and now I'm good to go .
    DaVette Boats
  11. #286
    Join Date
    Feb 2008
    Old Hangtown , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    ORIGINAL: Dana W
    I came up with a solution . With what little drive shaft I had left on the pump I managed to find a round collet with set screws for the 1/4'' pump shaft . I put a square drive collet on the engine . I installed a square drive flex shaft and now I'm good to go .
    Much better set up
    infinityteg .... I made the mistake of only getting the 5 blade impellor
    Reason I ask is because I have both and been running the 3 all along, but also running the RCMK Evo top end may have the power on hand for the 5 ?
    Running the 3 acceleration is instant like a light switch and rpm is @16K ....
    *So how snappy is yours with the 5 blade ?
  12. #287
    Join Date
    Oct 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    well dana i dont think youll have a problem with the flex shaft set up. mine and scotts has held up like that now for a while.
    scott
    without being able to compare the three blade with the 5 im not too sure of the difference. I find the accleration of the boat very good. While running the Zen in it turning you could hear revs drop off a little but it is definitly not as noticable with the EVO.
    cheers
    steve
    Infinity RC
    1/4 scale jet boats
  13. #288
    Join Date
    Feb 2008
    Old Hangtown , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    Hot dang !! .... found better performance, better intake loading and overall less blow outs and odd behavior with some intake mods !!
    Added an intake bubble made from a tea spoon then attached just ahead of leading edge on intake. A bit deeper angles on intakes leading and trailing edges done as well. Together hull is working great as is without the C/G changes I though it needed
    On smooth water now boat will run WOT without proposing what so ever, turns under full power generally brings a one point turn without loosing suction. Go crazy on steering and throttle boat will still unhook and do table top spins for giggles
    Will post a few pics of the mod later tonight .....
  14. #289
    Join Date
    Feb 2008
    Old Hangtown , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    Here is what the mods look like
ID:	1439126   Click image for larger version.
ID:	1439127   Click image for larger version.
  15. #290
    Join Date
    Jul 2006
    Bend, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    Interesting However I didn't have any porpoising with my CG moved back .
    DaVette Boats
  16. #291
    Join Date
    Feb 2008
    Old Hangtown , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    ORIGINAL: Dana W
    Dana,
    I know likely a crutch fix for the forward C/G, but had to try it out.
    But runs just great now, maybe the C/G will make it even better !!
    ** So with yours, what C/G % were you able to set yours up at ?
  17. #292
    Join Date
    Jul 2006
    Bend, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    I did what you suggested 27% .
    DaVette Boats
  18. #293
    Join Date
    Feb 2008
    Old Hangtown , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    ORIGINAL: Dana W
    Fair enough
  19. #294
    Join Date
    Aug 2005
    greendale, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    Dana W,
    here's the pics, this is a 40x15 inches warehouse hobbies jetski hull. thanks
    jul
ID:	1440754   Click image for larger version.
ID:	1440755   Click image for larger version.
    losi,warhead,dirtbike,,HTB360-2 ,HS Dumas,Nitro hammer, H&M Tunnnel,hydrofoamie,nomadio sensor,cat31,OB SW36
  20. #295
    Join Date
    Feb 2008
    Old Hangtown , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    ORIGINAL: wave waker
    Dana W,
    jul
    Well that's very cool
  21. #296
    Join Date
    Oct 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    Cool. that'll be an interesting project
    Infinity RC
    1/4 scale jet boats
  22. #297
    Join Date
    Jul 2006
    Bend, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    WOW , I didn't know they where making a jet ski . I'll look into what pump they're using .
    DaVette Boats
  23. #298
    cheesewizz69's Avatar
    Join Date
    Jul 2008
    Hialeah, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    ORIGINAL: Dana W
    Tony made a few of them in the late 80's and into the 90's. He still has the molds but I don't think they sold very well.
    Si vis pacem, para bellum
  24. #299
    Join Date
    Sep 2008
    West Bend, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    ORIGINAL: Dana W
    I've been thinking about building a boat like this for a long time. Would the KMB hold up long-term to a Zen/RCMK? I had a KMB drive a few years ago but never used it & sold it. I remember paying WAY more for it than they seem to go for now.
    Would the KMB would be ok just for playing around? How much more are the Graupner drives & what kind of extra performance to you get?
  25. #300
    Join Date
    May 2010
    , NEW ZEALAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    Hey everyone
    Im just about to get started on a gas jet boat build and have been following this thread thought it was time to say hey
    And im looking for a bit of advice everyones input would be appreciated
    Currently looking at getting a hull 780mm long 350mm wide
    Running a RCMK or Zenaoh gas engine
    A 2347 49mm impellor diameter graupner jet unit  [ would rather a swashdrive  ]
    How do you think this will all stack up together?
    has anyone been running this unit in there jet boat cant seem to find much info on it
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
