Speed - RC Gas Boats Discuss gas RC boats right here!
Gas Jet Boaters
Reply
Old 05-25-2010, 06:21 AM
  #301
Dana W
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Gas Jet Boaters
The KMB works fine I just think the 40mm impeller is alittle small for a Zenoah . Just make sure you use a good coupler . I'll be testing a different coupler soon . More info on that shortly . There is a customer here that purchased a DaVette Sprint boat that is installing a Graupner pump but havn't heard the test results yet . Maybe Scott can fill us in
Dana W is offline
Old 05-25-2010, 07:45 AM
  #302
timjz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What do the Graupner pumps go for? I can't seem to find a price anywhere. Also, do they offr a trim adjustment on the nozzle?
timjz is offline
Old 05-25-2010, 10:42 AM
  #303
Scott Schneider
Scott Schneider's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Dana W
Funny thing, Dave just approached me last week at our race where I was running mine ... hey Scotty got time to put mine together ?
Sadly had to decline not having the time now spring/summer is here [] Seen the pump tho ... simple as heck & in no way close to the caliber of the Swash pump. Has an up/down reverse bucket and steering, No nosile trim.
Scott Schneider is offline
Old 05-25-2010, 02:31 PM
  #304
daniel53
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: timjz
http://www.highperformancemodels.com...et%20units.htm
http://www.cornwallmodelboats.co.uk/...upner_jet.html
Yes I was looking at getting the 3 pin coupling that graupner make for the unit and zenoah
How about the hull any thoughts on the size?
daniel53 is offline
Old 05-25-2010, 02:41 PM
  #305
Scott Schneider
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: daniel53
Most of the GAS power squirt hulls are @ 1 meter or less in length (*34-36" and fairly wide) Short and wide bodied are the sprint hulls [>:]
Quote:
ORIGINAL: timjz
Old 05-25-2010, 02:49 PM
  #306
daniel53
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Scott Schneider
Quote:
ORIGINAL: daniel53
Quote:
ORIGINAL: timjz
do you think with 780mm long the CG will be to far forward, think it will prime ok? or should I look for a longer hull?
daniel53 is offline
Old 05-25-2010, 03:18 PM
  #307
infinityteg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
personally i think that 780mm (30") is a little bit small for the ZEN and RCMK option. if you do go that route it is going to be one heck of a ride. Mine is 1m (40") long. the davette boats i think are around 36" mark (someone correct me if im wrong). the small the boat the harder it is goingto be to cram all the running gear in. As for the 3pin coupler. i think they are quite expensive for what you are getting. I just use 2 collets and a flex shat in between.
cheers
steve
infinityteg is offline
Old 05-25-2010, 06:22 PM
  #308
daniel53
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: infinityteg
cheers
steve
Hey steve thanks for your advise, im still pretty keen to give the small hull a try do you think there will be any other issues rather than just fitting the driveline in ?
Heres one Iprepared earlier the unit is just a guess as Idont know how long the inside part of the unit is? ive guessed 190mm
daniel53 is offline
Old 05-25-2010, 06:33 PM
  #309
Scott Schneider
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
While a grey area in rigging it all ... using the smaller pumps like a KMB 40mm would be VERY TRICK using one of the Zenaoh 20cc engines with a marine conversion in a 30" hull
Old 05-25-2010, 06:53 PM
  #310
daniel53
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry Ididnt quite understand what you mean there? KMB 40mm?
I was thinking of a 49mm Graupner with the 30" hull and the Zenoah
daniel53 is offline
Old 05-25-2010, 07:16 PM
  #311
Dana W
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah a 30" hull would work but I'd still make the engine compartment at least 20" . That will give you enough room to work inside . You'll still want to place your CG 9" from the transom . The DaVette Sprint boat is 34" long and I feel that's pretty symmetrical .
Dana W is offline
Old 05-25-2010, 07:43 PM
  #312
daniel53
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Dana W
On my cardboard model the rear of the engine is 9" from the transom do you think that would be about right?
daniel53 is offline
Old 05-25-2010, 08:15 PM
  #313
dicko
dicko's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got a little more done. Here's some pics of the rollbar being mounted in the hull. The full process of building the carbon rollbar is over on the Snikwah forum.
ID:	1442452   Click image for larger version
ID:	1442453   Click image for larger version
dicko is offline
Old 05-25-2010, 08:21 PM
  #314
infinityteg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Its going to be very tight but worth a go. to get the CG back enough you might have to place the radio gear above/around the drive line.
The KMB 40mm is a jet unit that Dana is using in his sprint boat. it has a 40mm ipellor rather than the Graupners being 50mm< Scott thinks that a Zen or Rcmk will be abit too much torque for the 40mm unit.
Where abouts in NZ are you. were more than welcome to come round and have a look at mine for some ideas if your in the auck region?
cheers
steve
Old 05-25-2010, 08:45 PM
  #315
daniel53
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
cheers
steve
Unfortunatly im in Dunedin and Ijust about need a jet boat to travel around at the moment due to flooding
I think Iwill just have to give it a go and see what happens, it doesnt seem that im doing anything majorly wrong, will be interesting to see how it pans out. Would be nice to talk to some one that has used the graupner jet unit before to see how it performs
ID:	1442493   Click image for larger version
ID:	1442494   Click image for larger version
ID:	1442495   Click image for larger version
daniel53 is offline
Old 05-29-2010, 08:21 PM
  #316
aussier6er
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
guys i am looking to buy a jet unit does anybody have a swashdrive unit that they want to sell ??
i have been looking at the graupner unit but i would prefer to hold off untill i could hopefully find a swashdrive unit !!
thanks
aussier6er is offline
Old 05-29-2010, 11:42 PM
  #317
Scott Schneider
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: aussier6er
thanks
The Swashdrive pumps are the gold standard in pumps and VERY sought after ..... hope you can find one
Old 05-31-2010, 03:56 AM
  #318
aussier6er
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
after looking at the graupner units could someone please advise how these are mounted in to the hull ?
Old 05-31-2010, 07:20 AM
  #319
Dana W
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I heard you glass it in . Similar to the KMB installation .
Dana W is offline
Old 06-04-2010, 03:17 AM
  #320
dicko
dicko's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's the latest on my build. I've got the engine mounted, the radio box & linkages installed & all the trims set up. I had to make an extension to the coil relocator so that I could still use the over pullstart relocator, yet shift the recoil 90 degrees to allow the trim push rod room to pass the engine. I just need to drop it off to get the custom pipe made up & then get teh 29cc top end kit modified. After that I'll do the fuel tank & lines then test it before I add the design work.
I've added the pool noodle after I took these pics too.
Here's the pics.
ID:	1447757   Click image for larger version
ID:	1447758   Click image for larger version
ID:	1447759   Click image for larger version
dicko is offline
Old 06-04-2010, 05:42 PM
  #321
Scott Schneider
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dicko,
Looking good !! .... your spacing of pump/engine/radio gear looks very much like my Davette build.
*What C/G numbers are you coming up with set up the way you are showing it ?
Old 06-07-2010, 12:24 AM
  #322
dicko
dicko's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Scott,
The COG with the pool noodles in & without the pipe or fuel cell is at the front of the rollbar. I'm hoping once the tank & pipe are in the COG will be at the back or just behind the roll bar. I have an excess of noodles in there now, I can remove some to move the COGfurther back if required.
Cheers
Jason
dicko is offline
Old 06-07-2010, 08:04 PM
  #323
Scott Schneider
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: dicko
Hi Scott,
Cheers
Jason
That is fine and good .. was looking for actual numbers tho
Old 06-07-2010, 09:54 PM
  #324
dicko
dicko's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'll measure it when I get home from work. I'm on my lunch break now.
dicko is offline
Old 06-08-2010, 12:00 AM
  #325
Scott Schneider
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dicko,
Yours ..... [img]{akamaiimageforum}/upfiles/91577/At55190.jpg[/img]
Mine ..... [img]{akamaiimageforum}/upfiles/404891/Ge96653.jpg[/img]
So close in lay out .... I do need to scrunch mine up a bit tighter and move the CG back tho ... Maybe next winter, right not it's running and getting played with [:@]
Reply
Display Modes
