If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 15 of 20 FirstFirst ... 51314151617 ... LastLast
Results 351 to 375 of 485
  1. #351
    Join Date
    Oct 2007
    Bountiful, UT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    Has anyone on here built a jet by hand? If so please let me know. I would like to try it as well.
  2. #352
    Join Date
    Jan 2010
    Sanctuary PointNSW, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    ORIGINAL: kamipalms
    Hey Mick,
    Yes it is a plug and I built the hull to accomidate the the Hobby king or MHZ pump
    I know pump choices are limited and depending on weather the Hobby King pump is going to be any good or not , there are not too many other options to choose from.
    I noticed that there are a few people having CG problems with the 36" hulls so I set the transom back another 1/2 inch.
    In the pic the black line was the origonal transom and the extention sits at an angle so it doesn't form part of the keel.
    Yep you are going to have your hands full with a 36" hull, i have one and i can tell you they are very touchy , but hey best of luck with the build though. and make sure you post the build thread.
    Mick
  3. #353
    Join Date
    Nov 2005
    boundbrook, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    Greetings kamipalms , can we see the bottom of the hull? John
  4. #354
    Join Date
    Oct 2009
    Mandurah, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    ORIGINAL: Outerlimits
    Here you go
    Plus another shot from the front - please excuse the dust ....
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1584094   Click image for larger version.
    Evolution RC Australia
    evorc.com.au
  5. #355
    Join Date
    Apr 2008
    Puyallup, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    Hey guys..... here's the link to my Davette with KMB jet and NEU1518y BL....... I know not gas, Dana has his powered with gas, think he is still running the KMB jet..... it is a little on the small side. (maybe ok for stock motors). Even my 1518y is a little to much for the KMB. If the HobbyKing jet is any good I hope to put one in DaVette drag hull w/ modded zen........
    I plan to put on a RC sprint boat race this summer...... will post more when I have it all together....???
    here's the link, Jerry Dunlap was driving...........
    http://www.youtube.com/watch?v=dRSWGYgZz-w
    Hobby shop owner
    NW Nitro RC Hobbies
    Puyallup, WA
  6. #356
    dicko's Avatar
    Join Date
    Feb 2004
    Adelaide, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    Well I finally got around to start the build onthe Davette jetsprint hull with the MHZ unit.
    Here's a few pics. I've started the build thread on Modelgasboat.com
ID:	1584632   Click image for larger version.
ID:	1584633   Click image for larger version.
ID:	1584634   Click image for larger version.
ID:	1584635   Click image for larger version.
ID:	1584637   Click image for larger version.
    The answer is always more power.
  7. #357
    Join Date
    Sep 2011
    , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    I long for someone to take up production of the Swashdrive units again.
    HobbyKing had the new CNC JetPump - "PRODUCT ID: JETPUMP"
    Specs:
    Drive Shaft: 8mm
    Impeller Size: 53mm
    Impeller Blades: 4
    Output size looks to be about 30mm.
    No reversing bucket.
    No information on thrust.
    $369.99
    Reviews are generally positive on finish and first impressions but it sounds like the components might not last too long.
    Of course, the product is backordered.
    Plus, the vendor isn't very helpful with information about the unit. They actually said they weren't qualified to recommened anything about motors to go with the unit, and they cannot/will not tell me if there are spare parts available. They recommended that I search through their website for parts.
    So, it looks like we would need to buy two units and disassemble one for spare parts and also engineer the coupler and a reversing bucket.
    If production only lasts a couple of years then this turns out to be a very expensive set of holes in the hull of my boat.
    Anyone have updates for other Jet Pump units?
  8. #358
    Join Date
    Jun 2006
    morrinsvillewaikato, NEW ZEALAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    heres a real review those one on hk site are bull**** http://modeljetboat.com/forum/index.php?topic=628.0
    owner www.rcinnovations.co.nz
  9. #359
    Join Date
    Mar 2003
    BONNEY LAKE, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    So what should someone do. Pay more for the MHZ or go with the HK's unit.. I am getting tired of looking at the hull in the garage. HELP.
  10. #360
    Join Date
    Sep 2011
    , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    In the photos I see a brass fitting mounted at the top of the "bowl" just before the water exits the nozzle.
    Two questions:
    1. is that intended to be a place to hook in a feed line for cooling to the engine like a radiator hose would be used on a car?
    2. I wonder if you could record PSI from that fitting and then use that number to get a good calculation for thrust?
    (I would have inserted a photo but I'm getting the "500 Internal server error" message....)
    http://www.hobbyking.com/hobbyking/s...tpump-main.jpg
  11. #361
    Scott Schneider's Avatar
    Join Date
    Feb 2008
    Old Hangtown , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    ORIGINAL: Toochy
    In the photos I see a brass fitting mounted at the top of the ''bowl'' just before the water exits the nozzle.**
    Two questions:
    (I would have inserted a photo but I'm getting the ''500 Internal server error'' message....)
    Yes the fitting off the Bowl will be the cooling water supply.
    Pressure could be equated to thrust ... but what ever it is would have to be found out within a test cell with measuring equipment.
    I miss my swashdrive davette now, figured by this summer some decent pumps would be available [>:] ... this sucks !!
    Love the Hobby, Hate the Politics .....
    Home of MOTORHEADS RC Racing Engines.
  12. #362
    Join Date
    Sep 2011
    30780 US Hwy 264, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    my name is wes my rcu name is rc boat freak. im starting another jet this week as i just sold my scratch built pump on ebay . i have photos of a hull i built butt sold on my page and the pump.starting over from scratch i will posting pictures along the way .thanks
  13. #363
    Join Date
    Jun 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    ORIGINAL: cwoodyfly2001
    the hk units are ok but they do need a little work ..i just bought an hull to put mine in today ..but i dont think it will be going any time soon tho
  14. #364
    dicko's Avatar
    Join Date
    Feb 2004
    Adelaide, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    Here's some pics of my boat from the other week. The dayglow pink comes out orange in the pics.
ID:	1666205   Click image for larger version.
ID:	1666206   Click image for larger version.
ID:	1666207   Click image for larger version.
ID:	1666208   Click image for larger version.
  15. #365
    dicko's Avatar
    Join Date
    Feb 2004
    Adelaide, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    I've also been working on another hull for a friend. All it needs is the roll cage to be added and it's done. Dana's hull with an MHZ unit. I don't like the MHZ unit, but it's all that was available then. pics are taken on a phone, so excuse the quality.
ID:	1666211   Click image for larger version.
  16. #366
    dicko's Avatar
    Join Date
    Feb 2004
    Adelaide, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    Here's a pic of the rollbar sitting in place.
  17. #367
    sharpy022's Avatar
    Join Date
    Jun 2008
    guelph, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    any one out there buy and run a hk pump yet, want to know how they work before i buy, for my jet boat build
  18. #368
    Join Date
    Oct 2006
    Auckland, NEW ZEALAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    Heres one of the hulld i make with the HK unit in it
    http://www.youtube.com/watch?v=HFeY-19oOQY
    http://www.youtube.com/watch?v=gtt2u3-lt2Q
    http://www.youtube.com/watch?v=shBEgbUHlAc
    note: not my boat though
    cheers
    steve
    Infinity RC
    1/4 scale jet boats
  19. #369
    sharpy022's Avatar
    Join Date
    Jun 2008
    guelph, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    thanx for the vids, looks like the hk pump works well. i have some pix of a home built pump, i built this thing about 12 years ago, thought i would wipe the cobwebs off it and refab some new parts for it see if i can make it work better than before,the whole pump housing was made from a peice of nylon and the nozzel,change some of it to allu.last couple of pix are my jet boat from 12 years ago,it only went about 20 mph,so hopefully with the new parts i made it will work better, just have to build a new hull now,won,t be able to test till spring , the pond i go to is starting to freez over.
ID:	1704035   Click image for larger version.
ID:	1704036   Click image for larger version.
ID:	1704037   Click image for larger version.
ID:	1704038   Click image for larger version.
ID:	1704040   Click image for larger version.
ID:	1704041   Click image for larger version.
ID:	1704042   Click image for larger version.
ID:	1704043   Click image for larger version.
  20. #370
    Join Date
    May 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    ORIGINAL: sharpy022
    if you are going to redo the stator, give it more angle to the leading edge and have more curve to the blades instead of mainly straight.
    that will made it more efficient and go faster.
    Peter
  21. #371
    Join Date
    Jul 2006
    Bend, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    I'm going to post a few build photo's of a DaVette Sprint boat with a HobbyKing jet pump I'm putting together for a customer. It will have an RCMK engine with a wet dual exhaust . I decided to install everything first before I install the deck .
ID:	1737245   Click image for larger version.
    DaVette Boats
  22. #372
    Join Date
    Jul 2006
    Bend, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    A few more .
ID:	1737247   Click image for larger version.
    DaVette Boats
  23. #373
    Join Date
    Jul 2006
    Bend, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    Got the push rods connected .
    DaVette Boats
  24. #374
    Join Date
    May 2007
    Lockport, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    Good looking build you got going there Dana, is that carbon fiber?
    PS I'll be unveiling mine soon
    John
    \"If the facts dont fit the theory, change the facts.\" Albert Einstein
  25. #375
    Join Date
    Jul 2006
    Bend, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gas Jet Boaters
    No it's not carbon , it's just black tooling gel and glass. I'll be painting it on the outside .
    DaVette Boats
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
