Go Back  RCU Forums > RC Boats > Speed - RC Gas Boats
Reload this Page >
Gas Jet Boaters
Speed - RC Gas Boats Discuss gas RC boats right here!
Gas Jet Boaters
Old 07-12-2012, 03:27 AM
  #426
Dana W
Default RE: Gas Jet Boaters
The DaVette Sprint hull is 34" long . You can PM me on how to purchase a hull .
Dana
Old 07-12-2012, 03:30 AM
  #427
dicko
dicko's Avatar
My mistake, the Swashdrive must be 32".
Old 07-13-2012, 08:14 AM
  #428
EuroXS4
I see anything bigger??Or is that As big as they come?I saw this link on youtube looks bad ass bigger than 34" i think.You be the judge.
www.youtube.com/watch
Old 07-13-2012, 03:09 PM
  #429
infinityteg
thats a cool clip.
My hulls are 40" but i have been having a hard time getting them made. ive been pushing to have one for the last few months now. sounds like i may have one ready monday or tuesday (really hoping).
heres a link to my build. they dont come with the wing on the back like mine is pictured with.
http://modeljetboat.com/forum/index.php?topic=54.0
Old 07-13-2012, 03:19 PM
  #430
infinityteg
So if i do end up getting a hull (or two) this week i will be looking at builing me another one up very soon.
What do you guys recommend for an engine. I went from a weedeater (years ago) to a stock Zenoah 260 to the stock RCMK S254 seen above. the two options im thinking of at the moment are a RCMK K30 or the Zenoah 290 for the extra midrange torque, which would be the better motor to go for?
cheers
Steve
Old 07-15-2012, 04:48 PM
  #431
bentley marshall
hey steve i would go with the k30 ive sold a few to replace zens all the guys cant believe the difference
pm me i have them in stock can do you a deal on one ..
Old 08-25-2012, 07:19 PM
  #432
Mike2735
Tried this in the main Gas Boat Forum but no response, so I will try it here.
I have an idea that I have drawn up with Solidworks and would like you guys opinion.
I have a plan for a 50cc Twin driving 2 Jet Pumps piped into 1 outlet and nozzle.
Do any of you have any ideas about what I have planned or do you see problems with my design?
ID:	1795229   Click image for larger version
Old 08-26-2012, 06:22 PM
  #433
dicko
dicko's Avatar
Going from a singe engine, through a gearbox to twin pumps and back to a single outlet has four main issues I can see.
1 - loss of energy through gearbox and twin pumps
2 - flow problems where 2 pumps join into one nozzle (complicated stator required)
3 - you want the uptake as far back on the hull as possible, so you will have lots hanging out the rear
4 - when the hull leans over in turns you will likely suck air in one of the uptakes & cavitate/airate the system
Cheers
Jason
Old 08-27-2012, 06:48 AM
  #434
Mike2735
Thank you for your response. Those are the things I was looking at but I don't have alot of experience with a squirt boat.
Old 08-27-2012, 04:39 PM
  #435
dicko
dicko's Avatar
With jets you want torque more than rpm from your power source. I'd stick with a single engine to a single pump. When you design your impeller make sure the blades overlap so you get the best prime possible. The Jettec pump (re named swashdrive) is the only model jetpump currently on the market with overlapping blades. Not one of the Graupner, MH$ and Hobbyking pumps have overlapping blades and all, from my experience, suffer badly with cavitation and pump priming.
Old 10-08-2012, 01:07 AM
  #436
The Ghost
The Ghost's Avatar
Hi All,
Picked up a couple of new huls on Saterday, Started on one, will keep the other for a while before I start on it.
My latest boat, will be powered with a RCMK K30S, Jettec jet unit. Got the paint and carry handle/roll cage done. Should be finished in a couple of weeks.
Cheers
ID:	1809211   Click image for larger version
Old 10-08-2012, 11:12 AM
  #437
infinityteg
slowly getting mine new one put together, just need a roll cage made up and paint scheme now
cheers
steve
ID:	1809424   Click image for larger version
ID:	1809425   Click image for larger version
Old 10-10-2012, 04:01 PM
  #438
infinityteg
well got my sprint boat wet last night.
running 1/2 to 3/4 throttle most of the time though. I need to make my roll cage to add weight forward a bit and a spoiler to reduce swamping it when it spins out.
i am reasonably happy with it so far,nothing a bit of tweeking and tuning wont fix
heres a couple of vids
http://www.youtube.com/watch?v=2XaGhs2uorc&feature=plcp
http://www.youtube.com/watch?v=m0EcWdukZLo&feature=plcp
cheers
steve
Old 10-10-2012, 04:52 PM
  #439
Dana W
WOW pretty nice Steve . Good job .
Dana
Old 10-10-2012, 05:44 PM
  #440
The Ghost
The Ghost's Avatar
Steve,
looks great on the water, a bit tail heavy, may be able to move the fuel bladder foward.
Cheers
Old 10-11-2012, 04:20 AM
  #441
kamipalms
Just about to get a new design in the water.
Should be around a week away from testing
Old 10-11-2012, 02:03 PM
  #442
The Ghost
The Ghost's Avatar
ORIGINAL: kamipalms
[img][/img]
[img][/img]
[img][/img]
kamipalms,
looking good, can't wait to see it go.
Cheers
Old 10-14-2012, 09:33 PM
  #443
The Ghost
The Ghost's Avatar
Hi All,
Another one complete ready to get wet. Had problems with the 929 carby fitted standard, took it off chucked it in the ocean and fitted a 257 and it now runs great like it should.
Cheers
ID:	1811442   Click image for larger version
Old 10-15-2012, 08:39 AM
  #444
phillio35
looks wicked mate is it the davette sprint ,how did you the gasket between hull and pump thanks
Old 10-15-2012, 10:55 AM
  #445
infinityteg
it is a swashdrive jet sprint hull.
the gasket is made with a piece of rubber bike tube. it has a smaller hole cut in the middle to create a compression fit around the jet unit and the a flange fits over and bolts to the transom.
Old 10-15-2012, 01:05 PM
  #446
The Ghost
The Ghost's Avatar
ORIGINAL: phillio35
No it's not a Davette, it is made by a bloke out here, the seal is from a truck inertube, thicker than a bike tube. Will take photos of the next one that is on the go now.
Cheers
Old 10-15-2012, 06:04 PM
  #447
kamipalms
quick update
Almost done
Old 10-15-2012, 09:44 PM
  #448
The Ghost
The Ghost's Avatar
Kamipalms,
Its looking good, can't wait to see it run.
Cheers
Old 10-16-2012, 01:16 AM
  #449
kamipalms
ORIGINAL: The Ghost
Kamipalms,
Cheers
Thanks Mate
Finished and ready to build
Old 10-17-2012, 10:35 AM
  #450
phillio35
looks like mine phil
