Need A Little Help
My Feedback: (59)
IN
Need A Little Help
I installed A JR radio in my new enforicer. When I start it, It gos Full thro With out doing any thing. It works fine until I start it.
Any ideas?
Thanks for any help on this.
Tom
Any ideas?
Tom
MO
RE: Need A Little Help
I truley don't hve any facts. However I have read different post of bad spark plug, loose spark plug wire, bad grounds, etc causing interference with the radio??????
Are you running a Champion spark plug or the NGK CMR7H, if you haven't got the NGK plu in there do yourself a favour & swap it out for one, you need a good resistor plug in there. Also check for any metal rubbing on metal as this will create interference.
FL
As already mentioned I would start with the Plug.
1) It must be a resistor type plug. By no means ever ever ever use a champion plug.
2) Check for any metal on metal contact
3) Check for any loose wires. Battery, servo, switch etc....
4) Check your gray coil connection and make sure it has a proper ground
5) Check that your plug wire does not have any frays
