help locating a pipe
a while back i saw a few pics of a boat on this site that had a dry pipe that wrapped around the front of the motor before it went to the back of the boat. looked more like a dirtbike pipe or maybe something u would see on an hpi baja 5b, any ideas?
please post pics of your curved pipe set ups, no straight pipes please
thanks guys
thanks guys
RE: help locating a pipe
think you are on about a deep v header that goes from the engine to pipe
http://www.prestwich.ndirect.co.uk/wp222de1D.jpg
is this what you mean
regards phil
regards phil
MD
go here and look at some of their headers, maybe it's one of them http://www.bhhanson.com/hbprod6.htm
ORIGINAL: cat samich
ORIGINAL: Justaddwata
Sounds like something like the Mathe - I dont know of anything like it for Zenoahs - not as a boat pipe - maybe a car pipe
thats exactly what i was looking for, i was at work when i posted and didnt have access to my pictures at home. where do i find this pipe and will it work with the rcmk? these pics are the ones i was talking about when i posted
the motor in the cat you show is a Mathe engine and a genuine Mathe pipe. Matheengines.com are the manufacturer. The motors shown with the pipe are 35cc and the Mathe pipes are large (larger than those found on a QD35). I cannot see them being usable on a RCMK.
However - Mathe do have a smaller 24cc motor. I have only seen a few pipes on them and do not know if a Deep Vee pipe is offered by them for this smaller motor - it might work (with some modification). Could not hurt to send an e-mail to them with your application.
your the man! thank you so much. btw, what kind of power does that motor in the pics i put up make?
i looked at there website, looks like nice stuff. problem is i cant really find a retailer, can you buy factory direct? any idea on ball park cost of these motors? are they even worth fooling with?
Luigi is the US distributor out in California.
Last prices I got from Luigi put the motors competitive with Quickdraw (actually the advantage was with Mathe) though this was more than 2 years ago and prices and exchange rates have likely changed this (better or worse I do not know)
Mathe Motors are very well made - be it a little heavy duty. Some of their newer motors (Red heads) look to be lighter and sleeker. I imagine they are a step up in performance. I have a few of their older motors (big flywheel versions) which have worked flawlessly (not that I have asked much of them). But Mathe engines did hold the Gas speed record back in the 90's. They are not so common in the US. Only motors I have heard of with issues have been modified against the recommendation of Mathe (might be their reason for warning against it).
I have found with Mathe that they have a certain way they like things done with "their" motors. They will recommend a prop for a configuration and they do not like it when their motors are modified.
I have found with Mathe that they have a certain way they like things done with ''their'' motors. They will recommend a prop for a configuration and they do not like it when their motors are modified.
any thoughts on a qd 35 with one of those pipes?
ORIGINAL: quickdraw
What are you trying to fit it in?
Todd
Quickdraw
Todd
Quickdraw
im looking at a 56" or larger apache (expresscraft 70" or aeromarine 56" or an expresscraft arapaho
You could run a regular 90 pipe in those hulls and keep it concealed.
Those hull choices would work well with a choice of power - RCMK, QD25, Qd35 and so on. You have plenty of options
for arguments sake, what kind of combo would a qd 35 and the arapaho be?
KS
LOVE the QD DeepVee Pipes...this is a 25 RCMK EVO with the 25 DeepVee Pipe...in a Dumas Scarab. Keep in mind they do get a ittle toastie hence the name HOTPIPE but it is part of their design. If you are running a hatch make sure you have PLENTY of ventilation. I saneded, prepped, and de-greased and then painted mine with Hearder paint & wrapped with header wrap...I want to JetHot coat it and then wrap but it was not in the "hobby budget" this year... ;(
They make GREAT power and are SUPER compact. This is a 6" QD silencer
I understand the 25CC DeepVee Pipe and the 35CC DeepVee pipe are a little different in their exhaust outlet diameter?
Cat Samich, shoot me an e-mail...
