my project apache
My Feedback: (7)
RE: my project apache
I bought one ogf the Makita 18 volt coardless chargers/ sullivan starters, and I put the pully over the coupler.
There was a person making them all built together, NOTa Geeser wheel, but the same size so you do not have to redo the stuffing tubes, does anyone know where to get these at? you can have both the pull start, and thebelt start.
Also what belt has anyone found that grips the best???
Dave Marles sells 'em.must be somewhere in the US
http://www.prestwich.ndirect.co.uk/surfacedrive.htm HF201
I've tried one on a motor,only problem is leaving the belt in the hull when running,as we know gas boats get greasy with oil etc and the belt tends too slip,unlike the rear pulleys,where the belt is removed after a start.
Best bet with belts is to get a car fan belt and slice it the whole length with a sharp stanley knife,they will never snap.
FL
ORIGINAL: ByronRC
Does anyone know who makes this hull? I just noticed the clam shell design and was just wondering who made it.
Leo
#33
FL
ORIGINAL: F1madness
Get in touch with martno1fan he does some great apaches style hull from what iv seen
#34
Best way to do em is in the moulds but you need moulds made for the job,its very time consuming work and i aplaud anyone doing it the hard way like this which is removing the shoebox lip and filling and such as its a lot of work and not easy to do.I have no plans to make any clamshell hulls at the moment.Like the graphics they look nice,the boats a credit to your hard work well done.
Mart
Mart
#36
thanks for all the good comments its taken a bit off time and cash
its finshesd now had my 1st run on sunday and it was ok
hoping to get lots off use out off it now
thanks john
thanks john
