gas tunnel hull
is there such an animal as a gas tunnel hull? yup with a zen outboard.
RE: gas tunnel hull
Did you really just post a question, and then answer it in the same post?
RE: gas tunnel hull
ummmm no . i don't think so. i asked if there's a gas tunnel hull with a zen outboard. is there?
RE: gas tunnel hull
yes, search this forum, there's a thread on them.
RE: gas tunnel hull
Zippkits has a gas OB tunnel among others. Aeromarine's is so-so. Woodstuff is a good one but expensive and if you can find one.
The is one made overseas called an Ossi or something similar that not only runs good but looks good too. |
RE: gas tunnel hull
there are a few made in Australia too but shipping to USA would cost as much as the hull
RE: gas tunnel hull
1 Attachment(s)
this is my aeromarine 1/4 tunnel hull
RE: gas tunnel hull
dude your making me drool.
RE: gas tunnel hull
Go to my dossier (OMRA) Unable to load up pics at the moment.I have a aeromarine and woodstuff tunnels,the aeromarine is using a zen 7 and woodstuff is using a sikk 27cc
RE: gas tunnel hull
http://www.rcuniverse.com/forum/m_66..._tunnel/tm.htm
the other tunnel thread. that'll make you drool some more. |
RE: gas tunnel hull
1 Attachment(s)
check out my gallery home built tunnel with home built drive sharpy022
RE: gas tunnel hull
where did ya come up with the lines for your boats?
RE: gas tunnel hull
1 Attachment(s)
hey doom, the lines on most of the boats i build just kind a happen like that as i cut the foam, i use 1" foam layers so as you cut and carve the shape, gives good lines to mesure off of as you cut. as far as the design of them, i just look around these sites for pixs & info, you can find alot of nice pix to scale from
RE: gas tunnel hull
how do you keep the sponsons the same size? at the price of the lower unit for a outboard could i just use a cat setup? or would that not work? i have a MRP electric tunnel hull, and wonder how i could just scale it up for a gas tunnel?
RE: gas tunnel hull
1 Attachment(s)
hi doom,i cut the sponsons on the tablesaw to keep them the same, its the glass work thats hard,you could mok off your elec boat, just keep in mind,a tunnel hull is shallower & the bottom is laid out more flat, then a cat
check out the Oklahoma model boat assassination face book
Assassination? :D :D Sorry! Killer boats?
Insane Boats has a tunnel boat. I've seen it run. With a 26 it will run, but with a 29, it will RUN.
