Traxxas waterproof gear in Miss Vegas
MI
Just thought i would share a pic of a new radio gear setup i went with in my mod Miss Vegas. Basically used the Traxxas waterproof servos and a waterproof reciever box from a Rustler. I sealed up the flat 5 cell batt pack and mounted it forward and left of the fuel tank. She has been submerged several times, with no problems. I mounted all the gear on a piece of 1/8" ply, which is then bolted onto the original radio box blocks installed in the hull.
KY
RE: Traxxas waterproof gear in Miss Vegas
looks good, and i can vouch for that traxxas gear. used all of it exstensivly in my crawler, and no issues, i also have a 17in electric mono V, its all balsa, with the traxxas water proof brushless gear. works great, but runs a little hot still.... still working on props for it
TX
I use the Traxxas servos in ny Aquacraft airboat....and I have a Traxxas Blast....so I am familiar with the reciever box......what size is your fuel tank?
FL
Your header and pipe are mighty long, you will get a lot more RPM's from the engine if you shorten them up, from the pic that Looks like a MACS pipe you should start by cutting it down to 8.5"in measuring from the Stinger(Outlet) Forward. Then run the boat and see how it sounds and performs, if it still needs more RPM's you can cut about 1\8" off the header at a time and Test It until you get where you want to be. I see a lot of Bare Flex Shaft hanging out between the Flex coupler and Stuffing Tube,, That will present a real problem when you put a load on it, without the support of the stuffing tube the flex shaft Will Twist and Knot Up, you only want about 1\4" gap between the Flex coupler and stuffing tube if you put an Octura Flex Coupler on it you would be a lot closer to where it needs to be there a bit longer than what you have on it.
