O.S. 91 VR - Ducted Fan
RE: O.S. 91 VR - Ducted Fan
I'm going to stick with 25% nitro for the .91. It will be sucking down the fuel as is. The fuel tanks for a 44" Seaducer are a 4 oz. hopper and a 24 oz. main tank. [X(]
Here is the .91 ducted fan engine completely converted to a front exhaust marine engine. All ready to go into the Seaducer. The header is a MAC 15 degree header, glad I found it on their website. I was almost going to make a custom one. The one included with the ducted fan engine is a zero degree and is real short. The length in the picture is cut down to give a starting pipe length of 12.5".
AZ
Looking good, Craig. Now you can go out and kick some CMB tail! Is the Seaducer set up, yet?
Seeing that picture reminds me that those bosses on the case next to the exhaust header were drilled through and tapped for cooling water nipples.
ORIGINAL: kgibson4
Yah, I couldn't decided whether to drill those bosses for water cooling. I got nervous about messing up the case and decided not to bother. Most modern marine engines don't have cooling there anyways...
#31
ORIGINAL: advanced builder
You could add a cooling coil around your header if you feel more cooling is needed.
#33
Have you done any mods on that engine. Yet???
