Mac's Pipe and header
FL
RE: Mac's Pipe and header
The [link=http://www.macspro.com/specialapp.asp]2075 Header[/link] would be a better choice for a couple reasons,,
1: It's designed to go Out Around the radio box
2: It's a bigger Dia. so it allows freer flow and also matches up with the Dia. the tuned pipe will be when you cut it off, So getting a coupler to Seal to it is much easier and it won't let the coupler slide forward off the tuned pipe.
The 1324 Pipe works very well and will easily fit in the vegas, IMO it definitely improves Mid to Full RPM performance Characteristics,, On a Modified Engine,, (I Don't Run Stock),, But it Is Loud,, I install an Internal Stinger to take the Sharpness out of the noise but It's Still Not what you would call Quiet
The 1328 Pipe is a Bit Large for the vegas and requires a bit of modification to install it in the vegas, I've never run one so I'm not sure what performance changes it will make.
I have Never run an ST Engine or the New AQU Pipe, but in the original Vegas it was a Definite Improvement IMO. It's the set up I prefer with the O.S. and Go Engines, and as you can see from my vids it has worked Very Well for Me.[8D]
