Running Issue OS Max XM
Well I got my boat cranked and what I thought was idling decent on land. So I put it in the water and 20 feet away it stalled. I turn the mixture screw on land to richen it and it stalls. Any ideas. I turned the HSN 2 and 1/2 turns as indicated in the manual. Should I turn the HSN more to richen it more in the water under throttle.
Turn the mixture screw in to lean it out
Turn it outward to richen it
Is that correct?
Is that correct?
NB, CANADA
RE: Running Issue OS Max XM
weather it is the mixture screw (LSN small one in the carb barrel) or the needle assembly (HSN long one) they adjust like you said, in for lean and out for rich.
so yes, you are correct.
keep in mind that both of them need to be adjusted.
if its starts fine than you LSN should be pretty close, if it runs great on the table and it dies in the water than your HSN (long needle screw) is too lean.
once you have it set, you will have to blip the throttle on the bench so the engine doesn't load up and die.
Dan.
Dan.
it ran fine a minute ago for the first 25 yards and then it died. I have the HSN needle 2-1/2 turns I will go to 3 and try it when the glow plug starter charges.. should I go more then just 3 total turns .......just fished it out of the lake 4 times with my fishing pole. Its getting old going fishing for it.
It starts right up and idles great.
Well I figured out partially why its stalling. when turning right the throttle cable is to long thus closing the throttle blade and stalling. As for turning left. I have no clue. I cut a 55 gallon drum in half and going to use it for a test tank. That beats fishing in the lake for it. Ran about 75 yards before stalling this last time. I turned the HSN out to far and the needle came out. So that's where I am at. I turned it out 4 turns and just before it stalled it popped like it loaded up with fuel and partial backfire. Ideas? Is it to rich now. Is it a carb prob? Do I need a new carb. It fires and idles great.
One last note. With the HSN at 4 turns on land the throttle is still really responsive. It don't have a lag to it like its really rich.
where would I or how would I begin to find an air leak? I am open to any suggestions. The only way I would know to search for one is to spray the motor down with soapy water while running.
All that will do is pull the soapy water into the engine. Air leaks are normally found at the head, around the carb and through the bearings. I'm sure the engine guru's will show up eventually
NB, CANADA
it sure does sound like an air leak.
having the HSN so far out that it falls out and the engine is still running fine on the bench and not spitting fuel out the carb tells me something is not wright.
almost looks like the HSN is not doing its job what so ever, weather the HSN is 1 turn out or 4 turns out.
take the carb apart, clean it, set your needles and try it again.
if all else fails one of the bearings (if not both) could be leaking, they may only need to be cleaned or replaced.
bearings should be spinning nice and smooth, a leaking seal, or slightly rough bearing that leaks will make you chase the needle all day long and if not taken cared of, will always end up with a dead engine with more than just bearings to replace.
Dan
Dan
Got it running. Cleaning the carb again did th trick. Must have sucked up some trash from the tank or in the fuel. Ran almost a tank of fuel before it hit a turtle or fish and flipped over hull up in the water. The radio box got water. Hopefully the servos and battery will dry out. And all will be running again. Its running decent in the water has to be fine tuned I think now.
Back to water in the control box. Will the receiver, battery, and servos dry out and work again or are they JUNK?
NB, CANADA
glad you got it working and also glad it was just the carb.
open the receiver and the servos and dry them out.
once nice and dry get your self some corrosion X and spray the boards in the servos and the receiver.
there is a thread here that shows another method to water proofing, I will see if I can find it and will post the link. The corrosion X works great for me and many other boaters.
Now you need to fix the radio box, make her water tight, water in engine is no big deal but in the electronics, that can get expensive.
if you don't have one already, cut yourself a piece of plexiglass so it fits nicely inside that nice groove you have around the radio box, than use some good 3M clear tape.
make sure that everything else is sealed and there should not be any water going in.
Dan.
Dan.
finally got it figured out. Its running decent now. I can burn a full tank of fuel practically before it dies or I bring it in. Question is will I have to tune it again with a different prop on it.
ORIGINAL: dynacopas
Always set your high speed needle first, running at WOT. Start overly rich and lean it out noting when the RPMS sag a little at WOT. Richen 1/16-1/8 turn and you should be close to set. Now set your idle needle so it transitions from idle to WOT smoothly. Once you get a clean transition, richen only slightly and go have fun. If you adjust one, you adjust the other since at low-mid rpm both needles effect each other on most engines.
Well I got the steering situation pretty much solved. However when the boat is starting out getting moving. The nose is going almost 12 o'clock sky high. But the boat isn't going anywhere. Then its like the water catches up and gives the boat a kick in the butt. It did this several times and then it finally went. I am gradually leaning the motor out and its running a lot better. Is the boat cavitating? Is this is a prop issue. if so is it just a matter of a bigger prop.
Just curious but this statement here:
Inquiry Do you have the Cable anchored at the servo point and also anchored to the engine? Turning the outboard engine either direction should never change or Close the Carb.
See My pic.
You need to do this in order for an outboard throttle cable to work. See my pics on couple of Mine.
See My pic.
ORIGINAL: jw637362
See My pic.
See My pic.
