Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
cobra tunnel
Old 03-19-2012, 03:15 PM
bryston
Default cobra tunnel
I just got a cobra tunnel, does anyone have a pic for the radio box setup? any pics will help..thanks
Old 04-02-2012, 06:30 PM
bryston
Default RE: cobra tunnel
anyone? i need some pic to help with building/setup
thanks
Old 04-03-2012, 03:54 PM
HendricX
HendricX's Avatar
Ask the man who makes them ; Dan Hutchinson > hutchinsond15 [at] yahoo [dot] com
Sure he can help you with some set-up pictures.
Old 04-04-2012, 03:02 AM
Blackout
This is my Vision Craft, but it is the same for the Cobra. You can use regular rubber push rod seals. I'm the only one that does it that way.... You also have the option of using a push/pull flex cable with wheel servo arm. Go on the outboard section of Intlwaters and do a search.
Old 04-04-2012, 03:07 AM
Blackout
Also, I epoxied the radio box directly to the hull. I can't see ever needing to remove it....
