Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Props
Reply
Old 05-30-2012, 06:36 AM
wholehog
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Props
Is it necessary to polish a prop? I here it doesn't matter,and it does. Polish the side facing the front of the boat with a satin finish on the other side. Then I herd to satin the whole prop. Does any of this matter? Thanks
wholehog is offline
Old 05-30-2012, 09:11 AM
advanced builder
advanced builder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Props
only if you heat race. otherwise forget-about it.
advanced builder is offline
Old 05-30-2012, 10:05 AM
wholehog
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Props
I plan on racing. So what is best now. Thanks
wholehog is offline
Old 05-30-2012, 04:08 PM
coyv10
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Props
I have tried it both ways and have not seen a difference ( I like mine polished)
coyv10 is offline
Old 05-30-2012, 04:24 PM
advanced builder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Props
Quote:
ORIGINAL: wholehog
If you feel it will give you a edge, then Yes polish
Old 05-30-2012, 07:40 PM
Tundrahog
Tundrahog's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Props
A polished prop is a fast prop. I balance/polish/sharpen my own props. I have a couple done by the pro's. Don't see a difference. I do not do cupping/cutting. That I let the pro's do.
I have a gasser 55" cat and a small 16" electric hydro. Just added a .12 Zippkits rigger to the fleet. Hope to have the nitro in the water in a couple of weeks.
Tundrahog is offline
Old 05-31-2012, 05:23 AM
amax
amax's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Props
A Polished Prop will Slip through the water easier where a Sanded prop when done Right will Grab the water a push it the direction you want.
If your running a large aggressive prop and need it to Slip a little to let the engine get up in the RPM's You Polish It. BUT a Polished Prop will also Break Loose Easier in the turns or under Heavy Acceleration loads.
If you run a Smaller Prop that the engine has No Problem Turning Up you Sand the Blade surface to make it Grab the water and GO. A sanded prop will Launch Easier, Pull Turns Stronger, Hole Shot out of the turns Quicker, and Recover from a Spin Out\Stall Easier.
You just have to Experiment a little and figure out what works best for You and Your Driving Style and Boat set up.
amax is offline
advanced builder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Props
Joe over at Zippkits.com has a good selection of props. And a good price. I been running his Billet .21 prop on my .21 JAE rigger. MY .12 JAE i run his 438 -440 props
Old 05-31-2012, 06:26 AM
wholehog
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Props
Thanks everyone!
wholehog is offline
Old 05-31-2012, 07:22 AM
wholehog
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Props
For Top Speed: I have a 1/12 hydro. I am using a 1.34 x 2.06 s/s prop. It is sharpened and balanced. Is this a good prop for this boat or do you recommend something else? Thanks
wholehog is offline
Old 05-31-2012, 08:18 AM
amax
amax's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Props
If your running basically Stock engine & Set Up, The Octura Y535 (2 blade prop) for Top Speed, the Octura M435\3 (3 Blade) for Pulling Quick Turns and Hole Shots(Heat Racing). Stainless Steel is a bit Heavy for these small engines and the 1\8" Prop shaft, the Beryllium\Copper(Octura) is lighter and easier to work with when you S&B the prop.
amax is offline
Old 05-31-2012, 08:37 AM
advanced builder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Props
Quote:
ORIGINAL: amax
If your running basically Stock engine & Set Up, The Octura Y535 (2 blade prop) for Top Speed, the Octura M435\3 (3 Blade) for Pulling Quick Turns and Hole Shots(Heat Racing). Stainless Steel is a bit Heavy for these small engines and the 1\8'' Prop shaft, the Beryllium\Copper(Octura) is lighter and easier to work with when you S&B the prop.
When I got a billet prop or a AB it's always a little rough from machining. Same with Props4U -I did get his modded prop for the .12 and I was very happy. but delicate I tore that prop up a few years ago. You can't do what they do with a Dremal.
Reply
Display Modes
