Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
Reload this Page >
Flexshaft Woes!
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Flexshaft Woes!
Old 06-03-2012, 03:25 AM
James c harrell
My Feedback: (18)
James c harrell's Avatar
Default Flexshaft Woes!
Went to the river yesterday to try out a new prop and got my tunnel fired,tuned dropped her in and hit the throttle-instant nothing!! I had noticed that the last time I ran it the prop had dropped back about a quarter inch and figured that it had slipped at the engine collet. I slid it out and greased it from the engine side not really taking notice of the prop end. Re-positioned it and swapped props. Ready for the next run. NOT. It snapped the flexshaft about 3/4 the way from the engine, dropped the prop to the bottom of the river. I dont have any hard bends in the tube and it was fairly new as far as the driveline goes. Teflon lined tube and thrust washers and the cable is a 1/4 stepped to 3/16 that was new too. I bought the "good" cable grease and usually re-grease about every third run. What can I do to keep this from happening again. Twenty bucks a prop and a thirty buck cable hurts when they go to the bottom of the river.
ID:	1768459   Click image for larger version
ID:	1768460   Click image for larger version
Old 06-03-2012, 10:55 AM
Jerry Dunlap
Default RE: Flexshaft Woes!
There's two issues here: 1. Breaking the cable, 2. Loosing stub shaft and prop.
You didn't state what size OB you were running. Looking at the photos, it looks like a 7.5 cable. Cable will break.
I've stripped the threads for the stub shaft in K&B lower units making it impossible to tighten the stub shaft. As you discover, a loose stub shaft can come completely out of the lower unit.
JD
Old 06-03-2012, 12:32 PM
James c harrell
My Feedback: (18)
It is a O.S. 81 VR-M. The cable is a 1/4 inch stepped to a 3/16 but it broke almost 3 inches from the metal step part. Just to clarify, it isn't an O/B it is an inboard.
Old 06-03-2012, 12:45 PM
HendricX
HendricX's Avatar
2 Possibilities for this wound up cable :
NO end-play on your drive-dog / or Teflontubing too tight.
Leave cable-diameter as endplay , and ditch the teflon , use bare 7mm or 9/32" brass-tubing.
Old 06-03-2012, 01:01 PM
James c harrell
My Feedback: (18)
End-Play?? Explain this please. It may well be what is wrong if I understand it.
Old 06-03-2012, 01:37 PM
HendricX
HendricX's Avatar
Your drive-dog bearing should be 3 to 6mm / 1/8" to 1/4" (if using a 1/4 flex-cable) from your strut .
Flex-cables tend to shorten themselves (wind-up) during acceleration.
The cheaper the cable .. the worse it gets :-)
Try to find the stiffer 'golden-stranded' Sühner cable ... [link=http://www.gizmomotors.com/index.php?option=com_virtuemart&page=shop.browse&category_id=9&Itemid=56]Gizmo's[/link] sells them.
Old 06-03-2012, 01:47 PM
James c harrell
My Feedback: (18)
That would be the problem. I had thought the thrust washers should be a little loose, like as very little loose, and that is how I set it. Live and learn. Gotta learn somewhere. Appreciate the tip and or lesson. Any-one know where I can get a book "R/C Boating For Dummies"? Kidding. You got a link to Gizmos'?
Old 06-04-2012, 05:46 AM
Ron Olson
Ron Olson's Avatar
Is the boat a Catamaran? You have to be more specific as otherwise we're thinking a tunnel boat with an outboard. I knew the cable looked awfully long for an outboard!
OK, I'm thinking of 2 other things. Most inboard nitro-powered boats use a standard round collet, not one for a square drive. If your using the regular collet setup, ditch the thrust washers, you don't need them.
Failure to have a 1/4" gap between the strut and drive dog will cause breakage, been there. If it's breaking at the same place on the cable then I'd be looking for a kink in the stuffing tube that's rubbing hard in one spot.
This here is the result of a tube without a Teflon liner that I assumed my boating buddy got a kink in somehow during the winter. We took this shot just a week ago.
www.gizmomotors.com
