Inboard starting belt options (who makes one that can handle power)
IL
I have a 90cc inboard engine and am looking for the strongest starting belt I can buy. I have used prather and others of the same quality. But keep shredding them. Is there a better one out there maybe even one like an automotive belt?
OK
RE: Inboard starting belt options (who makes one that can handle power)
Check out Stock Drive Products. I bought parts from them when I was making a belt drive for a 75cc gas engine.
http://www.sdp-si.com/
IL
Brian are you saying the Prather belts are sewing machine belts? Or are you saying to try sewing machine belts?
Yes to both, some vacuum cleaners use similar belts as well. If you have a local repair shop you might get lucky and get some used ones for free.
My Feedback: (7)
MO
Go to a local automotive store and get a Gates 2L series..several different lengths and will probably have to order but I got mine from Oreillys and work great on my .45 and my CMB .90
[email protected], tim jones has what you need.
I have used this kind
http://www.royalsupply.com/store/pc/...p39732.htm#top
