Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Engine Prop Combination 30 Inch Deep V
Reply
Old 10-09-2012, 10:18 PM
RyanG91
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Engine Prop Combination 30 Inch Deep V
Hello,
I have been into fast electrics for a while and am eager to make the switch to nitro. I have a 30inch (75cm) semi deep V hull lying around that im currently in the process of converting to surface drive.
If anyone could shed some light on what prop/engine combination would suit this set up id greatly appreciate it. Ideally I would like the boat to be capable of 50mph.
Thanks in advance,
Ryan.
RyanG91 is offline
Old 10-09-2012, 10:46 PM
Hydro Junkie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Engine Prop Combination 30 Inch Deep V
I would start out with an OS .18 or a Nova Rossi .21 for that size hull. To go bigger than the .21 is asking for problems in keeping the boat on the water
Hydro Junkie is offline
Old 10-10-2012, 03:00 AM
Blackout
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Aaron Alberico is the Australian Novarossi distributor. Contact him for a .21 Novarossi and he can suggest props. Novarossi has a number of .21 options.
http://118.139.175.21/ozspec/index.html
Blackout is offline
Old 10-10-2012, 05:58 AM
amax
amax's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If your wanting to run 50mph+ I would stay away from the .18's unless you have it seriously modified. Massive Mods is the Go Engine dealer in Australia and does Really nice work from what I hear.
[link=http://www.massivemods.com.au/index.php?cPath=33]Massive Mods[/link]
amax is offline
Old 10-22-2012, 04:21 PM
jmy2u
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you run a surface drive with a good 21 size engine I would start with a 440 3 blade, then move up to a 1614 chopper if the engine can turn it. A NR should pull it no problem, even the Go 21 motors will run well in a mono.
jmy2u is offline
Reply
Display Modes
