If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 5 of 5
  1. #1
    Join Date
    Jul 2012
    Australia, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    FE no more got a nitro outboard
    Hello all,
    Well I have taken the plunge after no sucess at all with a FE system on my VS1 I have taken the plunge into the world of nitro outboards. I bought a new Thunder tiger Pro as that was most of the budget gone.
    My question is about starters, doI need a 12 volt hand held starter or can I buy from somewhere an adaption for a cordless drill so I dont need to cary a car battery with me, and I already have the cordless drill.
    Cheers
  2. #2
    advanced builder's Avatar
    Join Date
    Feb 2006
    Baldwinsville, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: FE no more got a nitro outboard
    guys are using a 18 volt battery pack from your hand drill. Adding that to the starter Some add a older 4 wheeler starter. Or make your own ,and go wireless.
    http://www.mcmaster.com/#catalog/118/903/=k4rssv
    DC Voltage High-Amp Relays part #7995K42
    Look down at the bottom of the page for a layout.
    http://www.rcuniverse.com/forum/m_98...71/key_/tm.htm
    Stoney Pond Model Boat Club, Canandaigua, NY
    International racer
    http://neilsrcsite.shutterfly.com/
  3. #3
    Join Date
    Oct 2012
    HendersonvilleNORTH CAROLINA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I bought a replacement cone for a starter ( I believe a dubro) and use a drill on most of my nitro boats.  I don't believe it has the torque of a good aircraft starter but it will  fire up a 3.5 outboard no trouble.
    Double Gun Pro
  4. #4
    Join Date
    Feb 2008
    Canandaigua, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Some new engines can be hard to turn over with the starter because of a tight piston/liner fit. If this is the case with your Thunder Tiger, you can heat the head with a heat gun. This expands the sleeve and makes it easier to start the engine. I had to do this with my O.S. when I replaced the piston/sleeve with new ones.
    Once the engine is broken in, the starter needs very little amps to get the engine going.
    Craig Mapstone, IMPBA #20305S, Stony Pond Model Boat Club
    2012 D1 20 Hydro Champion
  5. #5
    Ron Olson's Avatar
    Join Date
    May 2002
    Kalamazoo, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    A new or hard-to-start engine can be cranked over easier if you loosen the glow plug.
    IMPBA 17238 S
    269 Racing Team
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
