Thunder cat running wet!
finally got my cat back out after about 3 years have done some mod's to it like more fiberglass were tube exit's bottom, some motor mods, trying diferent pipe boat handles fine but running really wet tank is still in stock location does a fair share of cavitating upon take off dont know if I raise or lower strut tried trimming prop to raise the nosre but didn't notice any diference using stock prop also how much do I trim off the rudder?
ON, CANADA
I took half inch off my rudder also use the rudder to help trim angling rudder bottom in will help lift the bow kick it back to lower the bow play with prop hight and trim angle take time to get it right my prop will cavitate at slow speeds launching and such but runs great otherwise
