i need help !!
i need help !!
i just tryed firin up my cen and it started up but alot of fuel comin out the exhost am i runnin it rich? its hard startin too takes a couple pulls or when i loosin the plug a lil when it gets started alot of fuel comes up the top and im huryin to tighten the plug this normal? an once i do get it goin i hit the throddle an it is slow gettin up its like it wants to die when i let it at idle it goes out
RE: i need help !!
I am with wronk way, justt I set my needles with very little movment at a time. This will help you from passing the setting that you need to be at, takes a little longer, but will help you learn the sounds and what to look for
RE: i need help !!
when starting the nitro engines they do get extra fuel in the carbs, leave the glow warmer on it and work the throttle a few times while it is running to clear some of the extra fuel out, then remove the warmer
