Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Unofficial Nitro Hammer Thread
Reply
Old 09-09-2004, 09:12 PM
RG501
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Offical Nitro Hammer Thread
how do you get the radio box out??? i tryed pullin it off but it wont budge.
RG501 is offline
Old 09-09-2004, 09:25 PM
ejp67
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I changed my mind. I am going to do a metalic charcle grey instead of black. I took the radio box out one time, what I had to do is take the pipe out and cut the epoxy with a knife. Once I got it started I just pulled and it broke loose. Be careful not to rip a chunk out of your stringers though. [X(]
The surface drive I am going to get is
http://offshoreelectrics.com/images/...ut_system1.JPG
ejp67 is offline
Old 09-09-2004, 09:53 PM
Russ Williamson
Russ Williamson's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Failsafe is a great electrical device to add to your radio system. It will help prevent a run-away in case your on-board rx battery gets too low in power to power your throttle servo and/or if you lose your tx signal.
A very good, small, lightweight unit is the DTXM4000 offered by Duratrax.
It install it, all you do is plug it in between your receiver and throttle servo. Turn on your tx then power up your rx, push the set button and your done.
If you lose power to the receiver while running your boat, your throttle will go to neutral install of what usually happens....full throttle run-away and damage to your boat.......
Hope this helps, have fun!
ORIGINAL: RG501
what does a failsafe do? what would it do if i put one in my nitro hammer?
Russ Williamson is offline
Old 09-10-2004, 08:09 AM
911Dispatch
911Dispatch's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If they want to get technical, show them this:
IC 9-13-2-198.5
Watercraft
Sec. 198.5. "Watercraft" means a contrivance used or designed for navigation on water, including a vessel, boat, motor vessel, steam vessel, sailboat, vessel operated by machinery either permanently or temporarily affixed, scow, tugboat, or any marine equipment that is capable of carrying passengers, except a ferry.
The sign is referring to a conveyance for people not an RC Boat however, if it's privately owned they can tell you that they don't want the RC Boat in there either. It sounds like they have a problem with noise in that area and probable have a noise ordinance in effect. I'd run the Hammer anyway until somebody tells you otherwise.
911Dispatch is offline
Old 09-10-2004, 07:58 PM
Nitro Kid
My Feedback: (9)
Nitro Kid's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I thought that the Nitro Hammer has some kind of failsafe, cuz when you turn it off it will just run in circles 'til it runs outta gas!
Nitro Kid is offline
Old 09-10-2004, 10:20 PM
  #31
ejp67
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
O.k. I guess I will run over there. I am going to start painting my boat this weekend hopefully. I will post pics when I get it primered and I will let you know how it goes. I am going to keep the color a secret so it is more exciting to see. Wish me LUCK!!!!!
ejp67 is offline
Old 09-10-2004, 11:11 PM
  #32
Russ Williamson
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Another thing that is cool about a failsafe if you lose battery power or it gets too low, you can easily program it to keep a little bit of throttle so it slowly allows the boat to come to shore, or go in circles so your engine does not rev full rpm's for the entire tank of fuel. This is really good if you get upside down and the engine goes to full rpm with no load. When that happens, you can just shut your radio off to bring the throttle setting down until the engine is starved for fuel and stops running. (which is only a few seconds anyway when it gets upside down, but it could help save an engine)
Old 09-11-2004, 04:41 PM
  #33
RG501
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
for the surface drive on the nitro hammer, what prop would you be able to put on it? would the surface drive make it go about 40? and would it be stable enough to drive?
RG501 is offline
Old 09-11-2004, 05:22 PM
  #34
ejp67
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It wouldn't make 40 but the handling would be better. You would run a way bigger prop than factrory. Not sure what size. It would point the prop thrust in the right direction rather then down into the water.
ejp67 is offline
Old 09-12-2004, 12:26 AM
  #35
ejp67
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got my nh all preped for primer. I primed the hatch and I hope the boat turns out as good. I will post some pics when it is all done. Wish me luck
ejp67 is offline
Old 09-14-2004, 05:39 PM
  #36
RG501
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i am finally building the ride pads. i really hope they work.
RG501 is offline
Old 09-25-2004, 09:45 PM
  #37
eas___1990
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
how much faster do the ride pads make the hammer go?
eas___1990 is offline
Old 09-26-2004, 01:11 PM
  #38
RG501
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well i put them on and they didnt do too much for me. it seemed more out of control and was hard to drive. plus i somehow got a little crack on the bottom of the boat. so i took them off and fixed the crack.
RG501 is offline
Old 09-26-2004, 07:03 PM
  #39
eas___1990
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
oh so they dont really help the boat get more speed.OH poo i need some ideas that dont cost more then about 10 dollars that increase speed,i know thata tuned pipe help but i have like 50 cents right now(lmao)and my friend is going to get a boat soon.
Old 09-26-2004, 07:42 PM
  #40
RG501
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well they might help but i couldnt really tell because when i went wide open, it would wobble so much and would flip.
RG501 is offline
Old 09-27-2004, 04:05 PM
  #41
eas___1990
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
YOU MEAN IT FLIPED,did you make new trim tabs for them?Man i dont no if i want to put them on any more.
Old 09-27-2004, 04:15 PM
  #42
RG501
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yeah, it got up on plane so high, and when goin full throttle, it would go so fast that it would flip out. i just used the original trim tabs.
RG501 is offline
Old 09-27-2004, 04:46 PM
  #43
eas___1990
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
that might be it then becuase the modified ones that ejp made were 2" long,which is like an inch longer.How high did it get from the original ride hieght?
Old 09-27-2004, 10:38 PM
  #44
GRANT ED
GRANT ED's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just a quick question. Has anyone changed engines in one of these?? I am thinking of getting one and putting a .21 OS engine in it.
GRANT ED is offline
Old 09-28-2004, 06:01 AM
  #45
RG501
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
im not sure on the exact height on how far it got up. but there was a noticeable diffrence.
i havent changed my engine.
RG501 is offline
Old 09-28-2004, 07:21 AM
  #46
GRANT ED
GRANT ED's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well after helping a friend run his engine in on his new hammer me and another friend have decided to each get one. I have thought about it and am not going to change engines.... Well not yet anyway. I think for now I might just put a tuned pipe on it and leave it at that. I would be interested to know what other cheap mods are effective.
GRANT ED is offline
Old 09-28-2004, 01:50 PM
  #47
RG501
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
some mods you could do are these:
buy a octura x427.
drill a 1in hole above the carb.
make ride pads and put bigger trim tabs on it.
shorten the rudder a bit.
RG501 is offline
Old 09-28-2004, 03:58 PM
  #48
eas___1990
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what does shortenning the ruder do?
Old 09-28-2004, 04:22 PM
  #49
RG501
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
shortening the rudder creates less drag therefore makeing it go faster. but leave enough rudder so it can still turn!
sometimes my NH will get airborn and the rudder will come all the way out of the water. big fun though.
RG501 is offline
Old 09-29-2004, 01:30 PM
  #50
eas___1990
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
how short is your rudder?????[sm=confused.gif]
