Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
Reload this Page >
Unofficial Nitro Hammer Thread
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Old 08-13-2006, 12:06 AM
  #701
rcsoar4fun
My Feedback: (12)
Default RE: Unofficial Nitro Hammer Thread
Anyone tried the props from the Miss Bud? My prop broke today, that is the only replacement I can get locally.
Old 08-13-2006, 08:34 PM
  #702
jelly bean
im not sure, but i think it might work, im probably rong.
Old 08-13-2006, 10:12 PM
  #703
rcsoar4fun
My Feedback: (12)
Nope, it doesnt work. I recut at the pond and it works, but not real well. I am going to order some new ones from Tower tonight. Also broke the rudder today
Kristopher
Old 08-14-2006, 08:10 AM
  #704
jelly bean
lol i knew i was rong!!
problem with my hammer, i never get to go to the lake lately[:@]hopefully i can get that fixed this weekend.
Old 08-17-2006, 09:47 AM
  #705
t munn
Do you guys know if the flywheel and prop nut from a .15 aqucraft engine will fit on the .18 o.s. cvr-m or .18 cvr-mx
thanks
terry
Old 08-17-2006, 06:07 PM
  #706
dicko
dicko's Avatar
it will. the aquacraft engine is made by OS.
Old 08-17-2006, 07:19 PM
  #707
wave waker
ORIGINAL: t munn
thanks
terry
+1 yup..seeing is beleiving.....flywheel, header fits perfect..if ur planning to get .18 os get the one with pull start cos the internal of OS with pull start is different from OS without pull start, aquacraft pull starter won't fit with OS .18 non pull starter, ,,unless u have belt starter......my 2 cents..
ID:	508874   Click image for larger version
Old 08-17-2006, 07:40 PM
  #708
t munn
Thanks guys, But the .18 o.s. is for my miss vegas and all I have for now in a .15 aqub flywheel.
I'll see if i can use the parts off the .15 temporarily until my .18 flywheels arrive...
I posted My question here becuase some guys have used the .18 in their hammers.
Terry
Old 08-20-2006, 09:23 PM
  #709
jelly bean
i just ran my hammer tonight and it ran ok. i had to adjust the trim tabs so it would stop wanting to turn but after i did that the fisherman got too close[&:]
i was hopen to get it wound out too. owell.
Were hopen to run it again
Old 09-03-2006, 05:01 PM
  #710
XD_Dan
Really just posting to bump this thread back to the first page.
My son and I took the NH to the lake today. It ran well and nothing broke, so it was a good day. I had to fatten her up a bit because the weather is in the 90's here, and the water was too warm to cool her well. I really need to get a bigger tank for this thing. Just an eighth of a turn out made the run times pretty short.
I followed some advice here and raised the rudder/rudder assembly up about a half inch. It made a noticeable difference. I also drilled a few small holes in the hatch (above the carb) and that seemed to help as well. Thanks folks.
The more we run my son's Nitro Hammer, the more I like it.
Old 09-03-2006, 06:28 PM
  #711
1outlaw
LOL...I was comin in tonight to bring this TTT......
We broke the boat in yesterday.Got 3 tanks through her before it started raining....We made no needle changes for the first 4 tanks...This morning we chopped 1" off the rudder(not sure how you guys are moving them up) and sharpend the bottom of the rudder and turn fins razor sharp.Bent the trim tabs up so there not pushing the bow down.Added a little swim noodle for some flotation.Added 4 screw to the radio box to seal it better than that cheesy pin.Wetsanded the wetted surface of the hull with 400grit just to dull the finish.I cut a small hole in each of the windshields....I believe the vacuum effect of this will draw the hot air out without me worrying about consuming someone else's spray.....I also made 2 small holes where the front of the canopy strarts the 2 vee's.
With the above done all i can say is wow very impressive...After some runs getting the mixture right...We put the slightly modded Vegas out and the Hammer at the same time....Amazingly the Vegas was faster but its did it on the very topend and the turns...The hammer stayed not far behind.....The biggest problem the Hammer had was the wake off the Vegas.....The hammer got its stickers washed a few times...lol...I seen the bottom of it a few times..lol....Always recoverd nicely...The hammer also took alot of spray and never hiccupped....
When we got home after cleanup we pulled the head off the hammer and pulled 2 of the 3 shims...Will see how that works possibly tomorrow...
Also built boat stands for the 2 boats.....Way better than the ones that came with the boats...[8D]
Will have another boat here Tuesday and on the water with it soon...
Old 09-03-2006, 06:35 PM
  #712
entity
Banned
My Feedback: (14)
can i ask why you scuff the bottom.. thanks.
Old 09-03-2006, 06:41 PM
  #713
1outlaw
Same reason you never wax the pad of any boat big or small......The idea is to create air under the boat or air bubbles....The more air you can get underneath a hull the faster it will go...A boat will always be faster in small chop rather then glass.....When its glass it acts like a suction cup.....If you have ever been to any type of boat races go look at the bottoms of the boats...There will be a dull and possibly rough surface on them...
Just to clarify...Big boat races....I havent been to a any RC boat races so im not sure there...I figure if it works for the big boys it cant hurt the little ones....[8D]
Old 09-03-2006, 06:44 PM
  #714
entity
Banned
My Feedback: (14)
ok.. cool.. no didn't know that.. maybe thats why i'm selling mine. lol.. but makes sense.
Old 09-05-2006, 05:43 PM
  #715
entity
Banned
My Feedback: (14)
i can get you guys some 2.4 ghz cams if you want.
Old 09-05-2006, 07:02 PM
  #716
wave waker
[sm=thumbup.gif]nice boats 1 OUTLAW!!..bet it's fun to watch this boats running...a carb vent will make a big difference in hammer..
Old 09-06-2006, 06:36 PM
  #717
eas___1990
i am in the process of building a new hull but there is hulls that would be suitable replacements on tower in the scratch and dent section, you didnt hear this from me though
Old 09-06-2006, 06:48 PM
  #718
entity
Banned
My Feedback: (14)
yeah.. you didn't hear from me that i'm a dealer and can get you rtr boats for better than tower..
Old 09-06-2006, 07:24 PM
  #719
1outlaw
That was a quick disappearance.....
Old 09-06-2006, 07:25 PM
  #720
entity
Banned
My Feedback: (14)
they deleted my post
Old 09-08-2006, 01:14 AM
  #721
littlepiston
My Feedback: (12)
i just got my NH and im not even going to try this sub prop thing it going surface drive or should i try it ???
Old 09-08-2006, 08:34 PM
  #722
wave waker
ORIGINAL: littlepiston
stock NH is fun to run a lot of fun[sm=bananahead.gif], enjoy it first then maybe when ur tired of it try to go surface drive...
Old 09-08-2006, 09:37 PM
  #723
littlepiston
My Feedback: (12)
well i tryed it and im tired !!!! if it hits a small wake it cavates sufac drive it is all though it was fast im hoping it will be faster
Old 09-08-2006, 10:38 PM
  #724
Ron Olson
Ron Olson's Avatar
If you want to go back about 20-something pages, you might find something from a person who did try a surface drive on his NH.
Old 09-13-2006, 08:32 PM
  #725
LTB105
Cool stands what diameter pipe did you use?
