Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Thunder Cat 31
Reply
Old 10-14-2009, 12:50 PM
  #2601
dawg1200
dawg1200's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Thunder Cat 31
What was done to my tank was cut the nipple off at the tank and use a metal thredded nipple to replace the plastic molded one
Quote:
ORIGINAL: TwistedLiquid
Quote:
Well, the bottom line going to the carb where it is connected to the tank leaks on mine. Use wire and twist it around it tight, thats what I did to prevent it from leaking.
Here might be a better cure for your leak. The wire may cut into your line due to vibration. If you will cut off a piece of fuel 1/8 in length, then place the piece of tubing over the end of a closed pair of needle nose pliers. Open the needle nose to stretch out the tubing, then take your fuel line and place it thru the center of your stretched out tubing and release the needle nose. You should have your 1/8 over the very end of your fuel..then connect it to the tank...no leak you should find.
dawg1200 is offline
Old 10-19-2009, 04:17 PM
  #2602
black talon
black talon's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
my bj 55 i have i ran for a year and had a great time doing it. i like to tinker so i tinkered as much as ran it. i have recently taken the guts out and put them in a conquest and hope to have good luck with that also.
black talon is offline
Old 10-25-2009, 03:52 PM
  #2603
race1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
has anyone put the thunder tiger 7.5 engine in a tc 31? I like the bigger motor and the clutch and the belt start. how critical is the bottom after my fuel mishap I had a guy at work fix it and paint it. but could never get him to clear and buff it the top is ok but the bottom is a little orange peel looking will it run ok or have it cleared and buffed out?
race1 is offline
Old 10-25-2009, 08:43 PM
  #2604
wave waker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: race1
i think nobody done it yet but that's a good idea swapping motor, i'l bet it will work with little modification, coz i put os .46 in mine,,,imo, just take a measurement of the engine with the clutch first, might be tight in tc31.
keep us updated if u go to this direction...
wave waker is offline
Old 11-21-2009, 11:28 PM
  #2605
rcguy1411
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
does any one know if hesco came out with the new hatch fot the tc 31 and where to get it if he did peice on it thanks for any info
rcguy1411 is offline
Old 03-03-2010, 11:35 PM
  #2606
Owen18
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Guys I'm getting ready for another season of great boating with My Thundercat, I was wondering if you guys knew of some simple mods that could boost performance or just overall a better boat.
Thanks, Owen
Owen18 is offline
Old 03-04-2010, 12:25 AM
  #2607
rcguy1411
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
every mod that can be done to improve on the tc 31 is here in the form its a long read but you will gain all the knoladge that we have all contributed over the many years this thred a few quick mod are port match the exhaust header cut about 1/2 inch off the rudder less drag make shure your prop is sharp and ballanced open up rear of the hatch to allow air to excape the hull changing the carb will help cant rember the best one but it is in the fourm i run mine with the stock engine as im teaching my 7 year old how to drive with it good luck with the read it si worth it in the long run
Old 03-04-2010, 10:51 AM
  #2608
Owen18
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the quick reply, I know well of this forum I have been reading it since 2008, I have read it all. When you say open up the back of the hatch, should I just drill some small to medium sized holes in the back of the hatch cover.
Thanks, Owen
Owen18 is offline
Old 03-04-2010, 02:11 PM
  #2609
rcguy1411
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
think the rule of thumb is twice as much out as two what comes in it is hard to do with the tc 31 but if you open up the back the hatch is weakend up big time i reinforced mine with a pice of brass and glued if on the back i opend up over the mounting bolt and enlarged the two existing holes
Old 03-06-2010, 10:34 AM
  #2610
Owen18
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK Thanks I don't know if ill be doing that yet because I don't want my back hatch braking or caving in to me when I drill it out.
Thanks ,Owen
Owen18 is offline
Old 04-12-2010, 01:42 PM
  #2611
Highvoltage272
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey guys i was just wondering what engines you guys have swapped out how fast you have gotten them to go and how difficult it was. i dont really like this dynamite .32, i really want to put the Rossi .21 Piranha. and i love this forum i found out a bunch of tips to make my boat better.
Highvoltage272 is offline
Old 04-23-2010, 09:09 PM
  #2612
yannicksjh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Alright, finaly got my two boats in the mail (a used blackjack 26 SS with a grim racer prop (sharpened and balanced, after market pipe) and a TC 31) The TC has some hull damge so its giving me the oportunity to fix, custom paint, open up some air vents in the back etc. I'll have lots of time doing this one right with some or all the mods from the very long thread, since i'll just use the BJ 26 in the mean time. Anyway, i need a prop or two, which ones should i get that won't be too hard on the motor. I remember reading it a few ago but now i can't find it? Also, where to order from (i live in Canada). thanks!!!!
yannicksjh is offline
Old 04-24-2010, 05:17 PM
  #2613
5bbasher
5bbasher's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yannicksjh, not sure which boat needs props but here is a link to the tc31 prop used by most of the guys in this thread. i just ordered one sharpened and balanced for my tc31.
http://www.funrcboats.com/ProductInfo.aspx?productid=OCM445
5bbasher is offline
Old 04-24-2010, 08:58 PM
  #2614
1150ap
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mike Hallam at hallam marine hobby out of London.
1150ap is offline
Old 04-24-2010, 10:08 PM
  #2615
Coyotechaser
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just got my tuned and modded engine back and went to install the flywheel. When I was tightening it on I noticed the pull cord got real tight. Almost like it was pulling itself in. So I went to unscrew it and now I cant get it off. Either way I turn it there seems to be an unreal amount of reistance. Any help or ideas would be greatly appreciated. Thanks.
Coyotechaser is offline
Old 04-25-2010, 08:10 AM
  #2616
wave waker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Coyotechaser
common cause of that is engine flooding, so remove the glow plug then try to pull the cord, don't let it squirt to ur face,it should work, then if not the cord might got tangled inside otherwise there's something seriously wrong with the engine..
HIGHVOLTAGE..,,imo, i'l put any engine that is bigger than the stock than gettin' smaller,,
Old 05-03-2010, 12:15 AM
  #2617
cooltruck64
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey guys, i bought me a tc31 today. i got it used for 175 bucks at a garage sale. ive been lookin at them for a while so i seen it and grabbed it. i havent got to run it yet. what are some good mods for this boat? there is some model boat club thats always running on sundays in delcity (oklahoma) i might have to go check them out next sunday and talk to them about it. also is there any cool paint schemes anyone has done with there tc31? i do paint and body work for a living and i was tryin to think of a cool paint scheme
cooltruck64 is offline
Old 05-03-2010, 01:34 AM
  #2618
rcguy1411
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the first two i would do as far as mods are remove 1/2" from the stock rudder . the next thing i did was port match the exhaust header with the stock exhaust header there is alot of restriction there is an aftermarket carb that is said to really wake up the engine it is in this thread somewhere and change the prop make shure the one on the boat now is ballanced and sharpened and tou have alot of reading to do and every question will be answered have fun and as far as paint i like to look as full size boat and pick and chose aspects of what i like
ID:	1429967   Click image for larger version
Old 05-03-2010, 10:37 PM
  #2619
Highvoltage272
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Guys well i have decided on doing a engine swap and as wave waker said go big or dont go at all i am going to put the O.S. 46 vx-m in my boat. The .32 doesnt cut it for me i want something that people are gonna take a double look at.
well i just though i would post a couple pictures of my boat with the mods i have done. one is the canopy i lost one in the bottom of lake pleasant in hum big cove somewhere then the one i have now has foam in it to keep it from sinking and bought aero marine cowl locks and they worked until it fliped and where i glues the lock on the canopy broke but good thing it now floated. Then made some body pin mounts for it and it seemed a lot easier that trying to make brass tabs and it work really well.
Second is i was running60% omega in my boat with a x646 and my boat would be really hot so i made a exhaust cooling coilwith its own inlet and moved the header cooling line to have its own inlet ,it stays a lot cooler after i didthat,i alsoport matched the header,put 2 autobailers one in each sponson. I also trimed therudder, and moved the preasure fitting to the pipe. Braized the preasure fitting on theheader and sealed it upreally nicely hasno leaks. Put the traxxas 2.4ghz radio and trans in my boat from my 4x4 slash thati sold to buy the boat. i painted it withhobby paint on the top(silver) that i got from the lhs and lexan h20 paint fromACE on the bottom(red)i love working on this boat and tuning it as much as i love driving it. heres the pictures
Anyone in the phoenix area?
ID:	1430399   Click image for larger version
ID:	1430400   Click image for larger version
Old 05-04-2010, 08:42 PM
  #2620
wave waker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
nice clean boat,,,any action shot?
Old 05-04-2010, 08:51 PM
  #2621
Highvoltage272
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yes they are on my laptop i will get some of the good ones later and post them.
Old 05-04-2010, 09:24 PM
  #2622
cooltruck64
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i think im gonna try to do something kind of like this paint scheme but not exactly
Old 05-04-2010, 09:26 PM
  #2623
Highvoltage272
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
These are them it was in a lake in munds park az , 40 degrees out with snow still on the ground. this were takin before i painted it but everything else was one it.
ID:	1430929   Click image for larger version
ID:	1430930   Click image for larger version
ID:	1430931   Click image for larger version
ID:	1430932   Click image for larger version
Old 05-04-2010, 09:39 PM
  #2624
nothinbetr2do
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
nice pics guys, i might have to get mine back out. the cost of fuel is killing me. i kinda got away from nitro [8D]
i love the os 46 mod, i think i might have to go it. i now have a build under my belt, so why not.
but it will have to wait for the bs 2 speed, i'm on the list
nothinbetr2do is offline
Old 05-04-2010, 09:57 PM
  #2625
rcguy1411
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i only have this one left plan on getting more this summer
Reply
Display Modes
