If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 106 of 116 FirstFirst ... 65696104105106107108 ... LastLast
Results 2,626 to 2,650 of 2877
  1. #2626
    Join Date
    Oct 2006
    Lasalle, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Thunder Cat 31
    Well I got this TC 31 that had some hull damage so it needed to be fixed. I Fixed it using some boat fiberglass resin, sanded it down completly, primed, painted, clear coated, waxed. I also painted the inside with some rubberized black paint for extra protection and LOOKS. I 've also done pretty much every mod located in the very long thread (moved the pressure line off the manifold and on to the pipe, removed head shims, ported out header to match the motors for even flow, cut down the rudder for less drag etc). I also sealed the gas even if it didn't leak but just in case. When i received it, the rear hatch that holds the canopy on was also broken so i made this peice of aluminum with added air vents. Now, the funny part, all these countless hours of work and now i have to sell it because i need the funds to get a new boat cover for my real boat, LOL. Anyway, here are some pics. Nothing special but i do like how the rear piece turned out. thanks
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1430956   Click image for larger version.
ID:	1430957   Click image for larger version.
  2. #2627
    Join Date
    Oct 2009
    glendale, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Thunder Cat 31
    I like the way the boat looks. What kind of paint is that on the inside. I have white nitro resistant lusterkote and with about ten costs in it is still peels a little. And what is a bs 2 speed. Is there a trans for these boats now. I should have my .46 in a couple of weeks and have some in action photos from lake Powell
  3. #2628
    Join Date
    Nov 2008
    hamilton, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Thunder Cat 31
    well lookin at yannickjh pic s i think i need to go check my garage lol great minds think alike thank god still there ! lol
ID:	1431081   Click image for larger version.
ID:	1431082   Click image for larger version.
ID:	1431083   Click image for larger version.
  4. #2629
    Join Date
    Feb 2006
    elkton, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Thunder Cat 31
    ORIGINAL: Highvoltage272
    no, no trans for boats. but that might be cool.
    it's for an hpi baja gas truck
    just say no to \"shelf queens\"
    aaf# 111285-25
    A.C.E. member
  5. #2630
    Join Date
    Aug 2005
    greendale, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Thunder Cat 31
    there you go! nice action shot guys..
    hey yannicksjh, that's that's a great mod for the canopy, mine is broke too.
    nothingbetr2do, you're getting 2 speed for the baja ha!.
    keep posting pics of your tc31[8D],,,
    i'm currently installing a .67 silver bullet outboard j-shape pipe, but i need to cut the header, hope this will tuned to my .46 os...post pics once i got a new cam.
    losi,warhead,dirtbike,,HTB360-2 ,HS Dumas,Nitro hammer, H&M Tunnnel,hydrofoamie,nomadio sensor,cat31,OB SW36
  6. #2631
    Join Date
    Oct 2009
    glendale, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Thunder Cat 31
    hey wave waker how fast is your boat with that .46? and is it still stable and controlable
  7. #2632
    Join Date
    Oct 2006
    Lasalle, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Thunder Cat 31
    The canopy was broken when i got it so i decided to make that piece of aluminum. I didn't plan on going all the way across but then i remembered that i wanted to add air vents. I remember reading somewhere in this thread that it would really weakend the canopy if i just drilled some more holes so why not do it this way. I know its not much more air but each hole is even bigger than the original two and now there's 6, plus it didn't turn out all that bad. thanks
  8. #2633
    Join Date
    Nov 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Thunder Cat 31
    i did the same thing on mine just put it on the inside of the hatch
  9. #2634
    Join Date
    Aug 2005
    greendale, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Thunder Cat 31
    my personal speed recorded with gps 48-51 mph, pretty consistent and stable,, got couple of vids in youtube,,, just my observation the tc31 can still handle few more mph.
  10. #2635
    Join Date
    Oct 2009
    glendale, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Thunder Cat 31
    thats good thats what i am looking for. i was looking up the specs on the .21 max and .46 max they both have the same horsepower but at different rpms the .46 has 2.5hp@28000 and the .21 has 2.5hp@33000 the higher rpm means higher speed so it would seem that it would be smarter to get the .21 or does the .46 have more torque
  11. #2636
    Join Date
    Nov 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Thunder Cat 31
    hp is nice but torque is the answer with boats i would go with the .46 the torque will also allow you to spin larger props
  12. #2637
    black talon's Avatar
    Join Date
    May 2008
    longwood, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Thunder Cat 31
    just on an aside,the shims in the 32,at least on mine were 2 brass and one aluminum. the brass ones can come out but the aluminum is there for clearance.
    One day at a time, it\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'s not always a race.
    Thundercat 31
    R42
    Conquest
    SS Motors
  13. #2638
    5bbasher's Avatar
    Join Date
    Mar 2010
    South, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Thunder Cat 31
    the tc31 may be old but it's new to me and a lot of fun to tinker with! thought i would show you guys what it looked like when i got it and what it looks like now. post yours along with set ups and speeds for me please. thanks
ID:	1435142   Click image for larger version.
ID:	1435143   Click image for larger version.
ID:	1435144   Click image for larger version.
ID:	1435145   Click image for larger version.
ID:	1435147   Click image for larger version.
ID:	1435148   Click image for larger version.
  14. #2639
    Join Date
    Aug 2005
    greendale, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Thunder Cat 31
    [quote]ORIGINAL: sippirat
    the tc31 may be old but it's new to me and a lot of fun to tinker with! thought i would show you guys what it looked like when i got it and what it looks like now. post yours along with set ups and speeds for me please. *thanks
    nice rudder mod on tc31, so what's the paint scheme will be?
    how's that KOS?
    ww
  15. #2640
    Join Date
    May 2007
    BloemfonteinFree State, SOUTH AFRICA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Thunder Cat 31
    Where is the best online place to buy a new TC31 hull only? Mine is damaged beyond repair....
    He who dies with the most toys, wins...
  16. #2641
    amax's Avatar
    Join Date
    Aug 2007
    Crawfordville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Thunder Cat 31
    Horizon Hobby
    Top Speed Hobbies llc. Gotta Need For Speed..
    www.youtube.com/user/topspeedhobbies
  17. #2642
    5bbasher's Avatar
    Join Date
    Mar 2010
    South, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Thunder Cat 31
    wave waker, the paint scheme will be PEARL WHITE WITH SILVER AIR INTAKES AND BLACK WINDSHIELD .lol thats the way i like it, nice clean look!
    ran her yesterday with 30% nitro m445 prop shaved rudder and she was just dancin a crossed the pondit was a lot of fun! "loose is fast" and she was loose! sorry no pics or vids
  18. #2643
    Join Date
    Jan 2006
    phila, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Thunder Cat 31
    I have been trying to find the supertigre carb and it looks like it is on backorder. Anyone know where I can find one?
  19. #2644
    Join Date
    May 2008
    longwood, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Thunder Cat 31
    the only place i've found them is tower
    Thundercat 31
    R42
    Conquest
    SS Motors
  20. #2645
    Join Date
    Jan 2006
    phila, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
  21. #2646
    Join Date
    Jan 2006
    phila, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Thunder Cat 31
    I was running my cat today hit something and broke the rudder! What are you guys using for a rudder for the cat besides the stock one?
  22. #2647
    Join Date
    Nov 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Thunder Cat 31
    i like the speedmaster hardware have had it on a few other boats havent upgraded it on my tc31 as with this boat im using the if it aint broke dont fix it rule although i did upgrade my flexshaft today when i broke the stock one today even got lucky and still had the prop but think i will order a few spares this week
  23. #2648
    Join Date
    Jan 2006
    phila, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Thunder Cat 31
    Has anyone ever put one of these on the TC? http://www3.towerhobbies.com/cgi-bin...7880&search=Go
  24. #2649
    Join Date
    Nov 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Thunder Cat 31
    should work fine but i would also get the bracket that goes with it also that rudder will also help some of the handling isues the TC 31 has
  25. #2650
    Join Date
    Jan 2006
    phila, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Thunder Cat 31
    Just ordered the rubber and bracket. I will post some pics when I install it and a vid of how it works out!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
