Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Thunder Cat 31
Reply
Old 06-11-2010, 09:52 AM
  #2651
1badmaro
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Thunder Cat 31
How much of a power increase can I expect by changing to a Macs tuned pipe over the stock pipe? Also is there any other pipes out there that you guys would recommend?
1badmaro is offline
Old 06-11-2010, 10:32 AM
  #2652
rcguy1411
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
not shure how mich you will gain over the stock pipe but one of the best things you can do is to open up the header (port match) the engine will breath alot better along with a Mac pipe you should see a marked increase in performance there is also a carberator change in here somewhere that is said to really suposed to wake this engine up
rcguy1411 is offline
Old 06-11-2010, 10:39 AM
  #2653
1badmaro
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The port match is already done and the carb is on back order. I just wanted to know if its worth spending the 36$ for the macs pipe? Thanks for the response though.
1badmaro is offline
Old 06-20-2010, 02:36 PM
  #2654
1badmaro
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I opted for the Aeromarine rudder upgrade instead of the SV rudder. And now that I had a chance to run the boat with the new rudder it was worth the $ http://www.funrcboats.com/ProductInf...ctID=AER1310TC
1badmaro is offline
Old 06-20-2010, 05:05 PM
  #2655
wave waker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: 1badmaro
i don't see any difference from stock rudder. i don't get what's the aeromarine talking about for the rudder description..do you have picture?
ww
wave waker is offline
Old 06-20-2010, 11:47 PM
  #2656
Serpents Den
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I was checking a few sites for pictures of that rudder as well, from what i gather tho, its similar to the 'old' rudder, or the .21 aeromarine system...only real difference performance wise i would guess is the balance / turning point of the rudder, instead of being in the middle like the stock one, it'll be at or near the leading edge...
I too have aquired just recently a TC31 and cant wait to start working on it...this will be my first boat to work on. i have almost 2 dozen planes, a dozen heli's, and a few cars in my collection atm, each type i also run both nitro and electrics.... i was actually looking at the speedmaster dual water inlet rudder gear and aeromaster machined strut for replacing the stock ones, i just havent decided on the length of the rudder bracket yet. i figure it will help with the hooking issue having a bit more length to it, but not sure which length i will try. the hull and canopy will both get overhauled and new facelift.....fuelproofing and strengthening in key areas....locks on front edge of cowl, autobailers....better venting in back of cowl, screen in front vents...new paint.. i plan to run the .32 stock for a while ( after i rip it down and go over it, rebuild if i have to..)move the pressure nippleoff the header,replace exhaust coupler and add cooling tubing of course, grease and adjust tigerdrive gears, once motor is broken / rebroken in, that'll get swapped out for a pull starter... less gear to carry around. i may try all the engine mods everyone has listed all thru this thread at a later date, i do like speed, but for me its all about having fun. i just have to kick my brother's butt to get his aquacraft 1:12 Miss Vegas going so we can run together, just like we do with our heli's or planes...more fun when there's more peeps than doing it alone in my opinion..... hell, who knows.... it might spur me to pick up another boat or 2....or 3........or more hehehe...
oh yea.... i also have a plan for an electric powered'rescue' boat as well..... will be soo much easier than using a fishing rod, swimming or paddling out if there's a flameout or mishap of some kind on the water...
Serpents Den is offline
Old 06-21-2010, 07:36 AM
  #2657
rcguy1411
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
welcome to the world of boats Serpents Den sounds like you have a good plan of atack for your first boat the TC31 is a blast to run i find its the boat i grab when iwant to get on the water when i don t have alot of time i only saw one thing with your plan PLEASE DON T SWIM FOR YOUR BOAT as we have lost too many people to this in the past if you must swim please use a PFD
Old 06-21-2010, 01:37 PM
  #2658
Serpents Den
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hehehe....trust me, i wont be swimming for the boat   and im a padi certified scuba diver too........the bottom of my last post, i mentioned to have plans making a 'rescue' boat to recover it for me
Old 06-21-2010, 04:17 PM
  #2659
rcguy1411
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the only reason i mentioned the DON T SWIM FOR YOUR BOAT is that a father and son were lost this year and several other s in the past
Old 06-21-2010, 06:16 PM
  #2660
wave waker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Serpents Den
nah! u don't need rescue boat, u have lot's of heli then build one as a rescue heli that will be awesome! watya think?[sm=49_49.gif]
post ur tc31 once upgrade is done,,,sound really cool..
ww
Old 06-21-2010, 06:50 PM
  #2661
nothinbetr2do
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: wave waker
Quote:
ORIGINAL: 1badmaro
ww
to me they kinda look like a stock rudder, with alittle mod to it. a properly modded stock rudder would have the materail cut back to the the shaft, with no material in front of the shaft. with a razor edge running down from the start of the shaft. if you look back in this thread you'll fing my postings. that i got the knowing how to from guys in this thread, like wave and others that have tested this boat for us
nothinbetr2do is offline
Old 06-22-2010, 02:13 AM
  #2662
Serpents Den
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
*agreed, quite a bit better than the stock rudder....ive read this forum thread front to back and appreciate and learned a bit from all the posters here let alonea few other sites i readthroughbefore deciding to get this boat... with experience in rc planes and racing cars ya gotta worry about the drag as much as you do boats. to me i think it would be better going for a different rudder though, breakaway bolt design with a narrower tapered design, and having the water input rudder seems to be more appealing than the non one using a metal tube water pickup somewhere else mounted on the boat, which would cause more drag...as for the length, it can always be cut down w/o having to worry if you are too close to the water pickup...plenty of room for this application. hence the reason im opting for the speedmaster setup for mine....
Old 06-25-2010, 05:31 PM
  #2663
rcguy1411
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well it finaly hapened tiger drive failed but not what you would expect the wand was toast top my surprise but seing i had a 12 volt starter and belt on hand im now going to use that was a way to wreck a day at the lake i had everything to change over at the lake wich was like glass dosent happen verry often where i run then realised that i left the 12 volt starter at home to free up some weight in my field box
Old 06-26-2010, 10:38 PM
  #2664
Serpents Den
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hehe ive been there with my Hirobo ZXX when i first started in Heli's....used to have a pull starter on engine, also brought a couple of planes out with me at same time and had my sullivan starter always available (had starter shaft for hirobo just in case pull start failed)  and one day forgot to bring the starter shaft because i had helped a friend out with his hirobo one day, then brought out mine to do some flying and the pull starter broke....
anyhow, im waiting for a few parts ive ordered for upgrades to my TC31...(pullstart, autobailers, cowl locks, etc) just got my Spektrum marine reciever in, way different from the other recievers i use in my cars.  antennas are quite long, one gets inserted up antenna tube like the fm or am radio's...other mounted inside fuse above water line...  well built and looking forward to seeing how well it does or doesnt work with this project...also waiting for extra water outlet from my local hobby shop, once those parts are in i can get the extra mounting stuff drilled and etc then start prepping hull and cowl for paint...hopefully by the time the paint job is finished, the speedmaster parts will be in and i can start reassembling the 'new' girl
Old 06-27-2010, 12:51 AM
  #2665
rcguy1411
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
grabbed a new wand and also have a belt installed on my boat so i should nt have any more problems with starting problems justy an extra couple of pounds to haul to the lake
Old 06-27-2010, 07:00 AM
  #2666
amax
amax's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
loosen your glow plug when starting, it will save your tiger drive or pull starts and your Rod.
amax is offline
Old 07-09-2010, 01:11 PM
  #2667
loosenut510
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
anyone know where to get the pull start to replace the tiger drive? i dont like having to keep the starter charged up and carry it too. i  would rather just pull the rope
loosenut510 is offline
Old 07-09-2010, 02:05 PM
  #2668
Serpents Den
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yea, i ordered mine right from Horizon hobby, the Dynamite 32m version is direct fit... part # DYN6480
Old 07-10-2010, 08:34 PM
  #2669
1badmaro
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What are you guys using for a replacement exhaust coupler on the TC31?
1badmaro is offline
Old 07-10-2010, 09:40 PM
  #2670
rcguy1411
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
im using the ones from venom for there 1/8 scale trucks as they are alot thicker have had the same one on for the last two years and hs held up great
Old 07-11-2010, 06:29 AM
  #2671
1badmaro
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Is this what you are talking about? http://www3.towerhobbies.com/cgi-bin...3&I=LXRHR9&P=K
1badmaro is offline
Old 07-11-2010, 10:43 AM
  #2672
rcguy1411
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
this is the one im using [link]http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXRHR3&P=SM[/link]
Old 07-11-2010, 12:22 PM
  #2673
sushi2me
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gee, isn't that purple pretty? Just kidding - it's good to know where to get various parts and Venom DOES make quality parts AND vehicles - wish I could afford their 34" brushless catamaran or the bigger dual-motored one even or the biggest zenoah-powered gas one - just beautiful boats! I'm just more into electric now - grab a couple or four batteries, maybe a DC charger, and go! I don't have that kind of money to throw around right now/anymore (disabled and retired) and I think I have enough Fast Electric (mini/micros and Slow Electric and Nitro and Gas) boats, let alone electric planes and nitro monster and stadium trucks! More than enough to keep anyone busy maintaining, modifying, OR building new planes (10 in the boxes waiting to be built? - I think I've lost it, either that or I should open one of those lhs's: local hobby shop!).
BUT - we all feel the need for speed and a lot of us like the nitro noise!
Good Boating, Everyone - now's the season.
Couldn't help myself with adding a picture of two of the King of Shaves - they did an incredible job for just getting into boats, you've got to admit it!
sushi2me is offline
Old 07-11-2010, 02:10 PM
  #2674
Serpents Den
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hmm...right now in the middle of priming my TC hull, plans for a neon green/black color scheme, with some gold pinstripes on edges of the black....the plan is for the sponsons and cockpit 'bubble' areas to be green, rest black....trying to figure out how im going to implement a 'snake skin' type effect inside the green paint on the sponsons....
Old 07-11-2010, 04:58 PM
  #2675
rcguy1411
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the purple was the only thing i could get localy at the time there seemsed to be a shortage on exhaust couplers when i needed mine and the purple ment eather sitting on the dock or running and they have turned out to be the best ones i ve ever gotten and have lasted alot longer than the stock ones and ill run anything that will get me on the water regardless of the colour
Reply
Display Modes
