which boat would be better
KS
aeromarine mean machine
proboat Thunder Cat 31
Im thinking of getting one and just wanting some opinions which is faster, better made, and parts easy to come by oh and mods like bigger motor in the future?
I was looking at the miss llumar but Not really wanting a hydro after thinking about it...
NY
RE: which boat would be better
aeromarine sprint cat 40/60 is a nice cat, it handels rough water really well, i think it goes for $219.00 dollars. alot of boaters that race, use this type of hull because you can up grade to a larger motor, all the way up to a .90(15cc) and it can handel it very well with the .90 ,,, if you are tight on money and you can afford the hull, but dont have the big bucks for the big motor,a pull start .32 will push it OK?but not really fast but fast enough . P.S. I recommend that you put a( OPS .45) in it to start with,aeromarine carries the engine also.if you plan to go bigger later on, this is the way to go!!
KS
only thing with the sprint cat is after getting everything needed the price is more than im wanting to spend rtr is what im wanting under 400$ Ive been the 1000$+ rout before I built the boat and couldnt bare to put it in the water! it was a 48" deep v Challenger all enforcer hardware and I built a 30cc homelite that was just killer i left out nothing on the motor inside and out custom everything I did bench run the engine but like i said couldnt bare to toss it in..lol
I have read the thread on the proboat cat here I just wish there was one on the aeromarine MM.18
My Feedback: (12)
SC
ORIGINAL: toyotatruckin
http://www.rcuniverse.com/forum/m_4155991/tm.htm
http://www.rcuniverse.com/forum/m_4208169/tm.htm
Jeez, I cannot believe I'm going to say something nice about a Horizon ProBoat, but I've had the opportunity to closely examine the ProBoat Thunder Cat 31. It's a rather nice RTR. Actually, it's a really nice RTR. I haven't seen one run, but I would think it would run in the mid 30s.
Aero Marine makes quality model boats. I've never seen their 18 Cat, but if it's anything like other Aero Marine products it would be well done.
Jerry Dunlap
AquaCraft Models
Jerry Dunlap
AquaCraft Models
Wow, Jerry, I can't believe it either! I saw the T-Cat at a LHS and it does look like ProBoat is finally starting to get their act together. There are stilll reports of flex cable failure though.
As far as the Mean Machine 18 goes, I was really impressed with the boat when I saw the first 2 prototypes and thought that this boat was going to raise the level for all RTR boats to have to meet. So far, I have seen unhappy owners of the boat. One person described it as "There are going to be 50,000 pissed off owners of this boat when they get theirs!" Performance is what was expected of it. This is Aeromarine's first shot at a RTR boat and with more in the works, things aren't looking good. It really needed a .21 in it instead of the .18, even if it was a sport engine.
KS
well went to the hobby shop today and bought the TC31 I just decided after trying to get ahold of aeromarine by email and phone with no luck and almost no reviews on the mm .18 and from the pictures of the motor mount I have found It looks like aeromarine needs to work on there RTR boat..My opinion..... I did get a cheaper price on the tc31 because I had them open the box and pull the boat out so i could get a good look at it and also look at the motor/stuffing tube alignment which is ok and we found the radio box had come loose from the stringers no big deal, a little epoxy will fix it right up, 20 bucks off.....Thanks for the info guys
