AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast!
#3476
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast!
Check your fuel lines and fuel tank for leaks , the o-ring on the cap tends to leak after time and you may not be getting the pressure from the pipe needed to get good fuel flow. Also crap in the tank like old fuel residue maybe crudding up your carb.
#3477
I'm running a sullivan tank now cuz the original was junk. I'll clean out the carb and put a filter in. Thanks for the tips.
#3478
WI
Hi Everyone
I am going to put the Macs 2.5 Pipe on the stock engine. I wanted to know if i have to cut it down or leave it at its original length? Also is the stock header ok or will i be better off with the macs header? For people who have the 2.5 pipe can you notice the difference compared to the stock pipe?
#3479
WA
ORIGINAL: bearsb66
Hi Everyone
Hi Everyone
#3480
Hey All!
Just bought a MV and I have a few questions.
Can I run ODonell 30%Nitro-11%Lub?
Could I use a Spektrum DSM RX-TX?
Looking to upgrade the prop and rudder, which ones are good? Not looking for ultra speed.
WA
ORIGINAL: DARKPHREAKX
Hey All!
Hey All!
Thanks for the info, unfortunatley my LHS only orders from 2 places and they dont carry the Octura line. Could I use a Grimracer 36X55, is it comparable/direct drop in?
Is this the turnfin your talking about?
[link]http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXMLL2[/link]
#3483
WA
That's the turn fin. Comes in several colors. The Grim 38x55 appears to be the Grim prop that Tower recommends. The tech specs on that prop says it is comparable to the Y535 Octura.
#3484
TX
The Grim prop is fine for messing around in the local pond, but if you want to race, the Y535 is noticably faster.
Sean
Sean
#3485
Theres no local racing here[&o] but ALOT of water. I would also like to upgrade the fuelcell. Could I use the following as a direct drop in?
[link]http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXFU50&P=7[/link]
#3486
NB, CANADA
if the 8oz fit sure, but it may be a bit heavy on the front.
I use the same tank but the 6oz.
Dan.
Dan.
#3487
WA
The stock MV fuel tank works great as long as it remains in good condition. If you need to replace it, use the 6 oz Sullivan tank.
#3488
I contacted AQ about my spiderwebed fuel cell. Kinda upset because nitro dripped out and caused the hull to bubble in a few places on the bottom. Easy fix but still... Thanks for the help guys!
#3489
Well kids, look what we have here, it may be time to start another thread! http://towerhobbies.com/products/aquacraft/aqub34.html
Yup, Aquacraft upgraded the Miss Vegas with the 2.4 Gig Tactic radio system plus dumped the Aquacraft .18 for the Super Tigre. She also comes with the Glenn Quarles designed Super Tigre Q 18 pipe which also should up the power plus be quieter.
#3490
OR
nice! i am not familiar with the supre tiger brand, but it looks promising, with nice radio gear to boot! would love to see someone run one against the older version, and see if there is an out of the box advantage over the old setup as far as speed and power......
good job aquacraft!!!
davey
davey
#3491
I don’t know if this helps but........
The boat is indeed faster then the old one. The new ST 18 is really quite powerful and holds up well.
Changes include
New Super Tigre motor with Super Start system (the 12V cord is trick!)
Changed sponsons
New Motor mounts
Tougher radio box plastic
new shorter header with cooling coil
new quiet pipe
and of course our new tactic 2.4 radio.
All in all the boat now runs in flat water as well as it does in rough.
The pipe is our response to being responsible boaters.. we (AquaCraft) want a quiet boat as well as a fast boat. The pipe is a FULL BLOWN RACE PIPE so take your time breaking in the motor. The pipe can be a tad peeky but when on the needle..
ROCK AND ROLL!
Grim
Changes include
Changed sponsons
New Motor mounts
new quiet pipe
ROCK AND ROLL!
Grim
#3494
I hate to say it but if the super tigre engine is like the ones they put into Duratrax trucks then Aquacraft made a GIANT step backwards. I had 4 of these engines and they were all junk.
#3495
ORIGINAL: dyna_rider98
The sponson mods are very similar to what many of us have added to our MVs.
JD(And yes, I have more than a passing interest in the Miss Vegas Deuce)
#3496
OR
agreed, wait and see as far as what's what with performance, etc.......
so, i'd love to see some side by side, or to that effect, type of photos of new to old with these sponsons............ hint hint..........
davey
davey
#3497
I've got an idea some of the sponson mods made were the results of some boaters up in Washington state that were also used in the U-1.
Mike was very excited about the new engine. We got it out of his hands long enough at the Toledo show to get a shot of it.
#3499
OH
From the motor specks it has way more power the the aquacraft.18 which it is a duratrax motor with aquacraft name on it..I hope this time around Aquacraft start to make replacements hulls!!!!!!!!!!!!!!!!!!!!!! Because there some that cant do sponsons mods or they end up crashing the hull.....Dynarider aquacraft and Duratrax motor are the same motor..I knew that since 07..Ron ,,we need a new thread for the new MV??? I wouldnt mind bring my MV thread back to life....
