AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast!
#3751
My Feedback: (20)
RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast!
Ahhh man!
I put a final coat of clear on my MV and it kinda looks foggy.... CRUD!
oh well, I will put on the stock graphics and snap a picture and get this boat in the water soon!
I cannot wait!
I cannot wait!
#3752
MI
ORIGINAL: coyv10
Did you move the engine forward any for the .32?
#3753
Looks like you made some nice brackets for the mounts. I just aquired a .32 for my Duece hop to be installing soon, I will be running the stock setup at this months race with the .20 hydro class from what I have read It should do well..
#3754
MI
ORIGINAL: coyv10
#3756
MI
Great Shots! That boat is definitely flying!
What fuel are you running with? Glow plug?
How deep is your strut set with that M445?
#3759
Hello,
I'm going to buy a Vegas today, but should I go for the Duce (Tower Hobbies) or a V1 fron my LHS? The plan is to put in a bigger engine STS .28, STS .30, O.S .46 or similar. I want pure speed.
Suggestions?
Suggestions?
#3761
MI
Definitely the Deuce. Sponson mod is already built in now. The stock boat will do 40 with Y535, 30% nitro, once broken in. This thing really airs out - just look at the previous pics posted by TreEsPaSS.
#3762
The Vegas that TreEsPaSS has don't look like a deuce.
It was explained one time like this...
The sponson mods were great to get more speed from a boat with less power,
they raise the front of the boat, get more air under the hull, and reduce drag.
But the original sponsons (trued up) were better for high speeds, when engine power is not a problem.
#3763
ORIGINAL: lomcevac540T
#3764
you can usually find them on ebay. [link]http://cgi.ebay.com/Miss-Vegas-Nitro-Radio-Controlled-Boat-NO-RESERVE_W0QQitemZ270441699567QQcmdZViewItemQQptZRa dio_Control_Vehicles?hash=item3ef794d8ef&_trksid=p3286.c0.m14[/link]
#3766
PA
ORIGINAL: KingofSpeed
Yes this is my concern also. The ''duce'' can probably get too high on the nose in speeds over above 50 mph. Then it may want to flip over. My LHS does not have a ''good price'' for the V1, it vill cost me the same as the Duce. It's just a matter of which will go fastest. I want to go ''unlimited'' when it comes to power.
#3767
My Feedback: (10)
VA
I have to keep 2 strips of lead on my V2 Vegas left sponson to keep it planted...did you want to stay nitro on your next hydro...or go gas?
#3769
MI
On another note - my 5 cell battery pack had a meltdown and caught fire during a run. Took out the batt, throttle servo, switch harness, and the plexi radio box cover. The boat had flipped when I turned too sharply too miss a boat that died in front of me. When I pulled the boat out of the water, we found the mess. Don't know if the flip caused it. There was no water in the radio box. Fortnately, easy fixes, could have been alot worse. Sorry - no pics of the burned up components.
#3771
Thank you for very good information. Based on what you say here and since I'm goining to put a bigger engine into the hull, I'll think the best choice is the Miss Vegas V1.
#3772
MI
ORIGINAL: srt10
I want a video of your MV ripping with this motor getting faster!
#3773
Jerry i have a question i have played with a few boats over the years mainly riggers but have made a sport 40 and a scale 60. i just got a mv the other day and noticed that the shaft is down quite a bit but is set 1 1/16 below the transom. I have always run straight shaft on my stuff and i have always set the prop shaft just slightly below the rear running surface. My question is if the shaft was raised up say 1/2inch could you not run a bigger prop.
#3774
Hi,
I just ordered the Miss Vegas VI. I was hoping that is was on stock in my LHS, but was sold out. Luckily, they had it in the central store and they will send her to me . I read that TwistedLiquid has managed 52,7 mph. Anybody else managed this with the .18 engine? This is pretty fast!
I will dismantle the engine, give it a flowport job, optimize compression ratio, knife the conrod and make a turbocut in the cranckshaft. Then bring her to the pond along with my speedgun and see how fast this baby is with the .18 engine. If this will not bring her above 53 mph, I put in my tuned, high-reving O.S .50 hyper
