If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 156 of 163 FirstFirst ... 56106146154155156157158 ... LastLast
Results 3,876 to 3,900 of 4068
  1. #3876
    Join Date
    Jul 2009
    Bellevue, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast!
    There are epoxy specific dyes that are like $5 to $10 for an ounce (more than plenty).
    I used 30 minute expoxy with a little dye (look back a few pages for my boat; orange hull with grey interior). I didn't thin my epoxy but you certainly could. If you've run your boat, the real trick is to get the hull clean before you coat it. I had really clean mine. Used alcohol and sanded it well - especially in corners - to get it clean.
    PS - be careful about covering the motor mounts. Can raise the engine height messing up the stuffing box alignment. I left mine uncovered. Also, don't fill too much under to collette lest it run and you have to grind it out.
    Miss Vegas Noob
    Bellevue, WA
  2. #3877
    Join Date
    Apr 2006
    Augusta, KS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    hey dan you say you added the testors paint to the epoxy, did it harden up like it should?
    http://www.youtube.com/user/toyotatruckin
    www.aircapitolhobbies.com
  3. #3878
    Dan S's Avatar
    Join Date
    Aug 2006
    Oromocto, NB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Mike,
    yes it hardened, it doesn't need a lot just a few drops.
    it took a little longer to cure but it did.
    I have been running it for 4 years now.
    Dan.
    F-41 Stryker Cat 260 Full Mod - Whiplash GV NFS 260 - FireFighter 18 - Miss Vegas CVRM 18
    Futaba FASST
  4. #3879
    Join Date
    Apr 2006
    Augusta, KS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    cool deal was just wondering, sometimes you go to adding things to epoxy and you end up with issues.
  5. #3880
    Join Date
    Mar 2009
    killeen, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I got my vegas put together and looking to start breaking in my engine.My question is this what prop should i use to break in my engine and then once i get it broke in what would be a good prop to race it with?I've got a GO.18 with the older version exhaust and a 3/16 flex-shaft.here's a few pic's of it....
  6. #3881
    Join Date
    Oct 2007
    , ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    does anyone know what the hp and rpm numers are for the aquacraft
  7. #3882
    Join Date
    Jan 2007
    Lubbock, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ok need some advise. Duece with the .32 nearing 55mph th hull starts rocking from side to side, and if I don't back off the throttle you see it go skipping across the water..
    Do I need to add weight to the front or what?
  8. #3883
    Join Date
    Jan 2005
    Chesapeake, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    We might be able to give better advice if we had a video of it doing that...I had to add about 6 oz. of weight to my left sponson to keep it on the water once I got it over the 50mph mark.
    Kevin
    Miss Vegas w/.18TZ , JAE 12 w/.18TZ
    Shrike 10 w/Cox/RJL .15 Conquest, Shrike 40 w/7.5Df, Shrike 10 w/RB .12 serpent.
  9. #3884
    Join Date
    Aug 2005
    Rochester Hills, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: coyv10
    Mine started doing that when I went with a really high pitch prop. I then changed to a lower pitch, but larger diameter, and no problem.
    Also remember, this hull really wasn't intended to be going this fast.
  10. #3885
    madmax93's Avatar
    Join Date
    Dec 2006
    halifax, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Does anbody know where I can get a rudder for the Vegas besides Tower Hobbies.
    KM baja...Dynamite...HPI Firestorm...Small Bolt...Easy Star...Wild Hawk
  11. #3886
    Join Date
    Mar 2008
    bardstown, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ebay?
  12. #3887
    Join Date
    Apr 2006
    Augusta, KS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    if looking for stock hit up ebay, aftermarket hit me up
  13. #3888
    Join Date
    Feb 2009
    Allentown, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    anyone know where a solid backplate / cover plate can be found that will fit the dynamite .32? similar to this http://www.dynamiterc.com/Products/D...ProdID=DYN0922
  14. #3889
    Join Date
    Feb 2009
    Allentown, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Still looking for .32 solid backplate?? Anyone know where I can find some .18 engine mounts? Would rather not fabricate. Thought I had them on way but guess not:
    1...Sorry there is a slight shipping delay in this item. We will have this item out to you in a couple of days. Once again sorry for the delay.
    - waldorfrccom
    2.. Dear waldorfrccom,
    I have not received these items yet? Is there a hold up?
    -trespass
    3...Dear trespass,
    the engine mount is on back order.
    - waldorfrccom
    Terrible ebay store..ironically, I live in VA. and receive product faster from Tower Hobbies than I do from this guy the next state over.
  15. #3890
    Join Date
    Dec 2009
    , MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thank you for the kind words Trespass.
    Yes your item was out of stock.
    It is posted that sometimes items are out of stock that are not indicated and a refund will be given.
    I am offering a 10% discount to anyone on RC Universe that mentions this post when ordering.
  16. #3891
    Join Date
    Feb 2009
    Allentown, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: WaldorfRC
    Yes your item was out of stock.*
    Great idea, unfortunatly 10% means nothing when your don't receive what you ordered. I will post your link for you : http://www.waldorfrc.com/servlet/the...-Engine/Detail
  17. #3892
    Join Date
    Aug 2005
    Rochester Hills, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey TrEsPass!
    Sitting here watching all the white stuff coming down outside. Be awhile before the Vegas gets back on the water. [&o]
    Just wondering if I mentioned the upgraded carb I put on my .32? Direct drop in from Super Tiger. Made a noticeable difference - much bigger carb opening.
    http://www3.towerhobbies.com/cgi-bin...&I=LXFW08&P=ML
    Talk to ya soon!
  18. #3893
    Join Date
    Oct 2008
    asdf, NT, INDONESIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I received miss vegas couple of days ago. I found the lid of the fuel tank is leaking and the boat is crack. this boat's design is very good. but the quality is not impressive at all. you guy have the same problem ? is all miss vegas made in china ? [sm=confused_smile.gif][sm=confused_smile.gif]
  19. #3894
    Join Date
    Jan 2005
    Chesapeake, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yes, A leaky fuel tank is very common...that's one of the first upgrades most guys do.
  20. #3895
    Join Date
    Feb 2009
    Allentown, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Sullivan 8oz tank will do you well.
  21. #3896
    Join Date
    Sep 2007
    Bremerton, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    only really need a 6oz but longer runs with 8 lol!
  22. #3897
    Join Date
    May 2008
    santee, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    hey everyone runing a .18TZ what props are you runing and have tried. Im useing a x440/3 and it seems to pull just fine with unmodded engine just looking for more speed. I also have a modded .18TZ on the way and need to know a good starting point for props?
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  23. #3898
    Join Date
    Jan 2005
    Chesapeake, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have a full mod .18TZ in my vegas and I tried all of the run of the mill standard Octura props with decent results, however I didn't start seeing what I would call best results until I tried the higher pitch props, but I was looking for all out speed and I wouldn't recommend them for racing. The fastest so far for me were the Octura 2137/3, 1938, V937. I also have a 2140/3 that I haven't tried yet because of the weather and other things, but I intend to try sometime this season. The 440/3 and the 640/3 were the best racing props so far with consistant results and performance. I also noticed that when my Vegas gets in the 50mph range it starts acting a little funny and wants to self destruct, but that might just be my hull and setup cause it's all stock for now and just and upgraded turn fin....but that's just me and my experience.
    Here's a vid I did some time back using a 2137/3..
    http://www.youtube.com/watch?v=qWHXrn68LAo
    Kevin
  24. #3899
    Join Date
    Jan 2008
    Frederick, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    That's a mean little mill in those boats! [:-]
    first to own the Mini Slash!
    Amsoil Dealer.. 6XL Revo, Baja 5B, Losi8T, PS295, UL-1, AQ MC, OM29, DF33
  25. #3900
    Join Date
    May 2008
    santee, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for the prop info FX4L2CX that should save alot of money playing with props! I also had trouble with the stability of the hull at high speeds but adding weight to the left sponson and doing my sponson mod really helped alot now im not scared to go faster! I have watched your video on youtube about 100 times now and thats been my target for about 1 1/2 years and now I hope to be not to far off your vegas! what nitro% are you running in that vide? I have been running 50%
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
