Prop for .21XM?
Prop for .21XM?
Which of the Aquacraft Grim Racer props would you get for the OS .21 XM outboard.It will be on a TS2 if that matters.
I'm assuming the stock prop isn't the greatest.
RE: Prop for .21XM?
The stock prop is not all that bad.. it does however not hold its shape under load. The blades are not as tough eather.
For your motor and hull I would use eather the 4052/3 or the 4053..
Keep us posted
grim
Keep us posted
grim
