View Poll Results: A poll
Voters: 17. You may not vote on this poll
Tunnels as part of Hydro Build Challenge?
RE: Tunnels as part of Hydro Build Challenge?
ORIGINAL: Hydro Junkie
Now Jerry, you're not patting yourself on the back are you?
JD
ORIGINAL: FurnalFlyer
OB PM sent to you..
OB PM sent to you..
Hey JD, the 34 plans you have, is that V1 or V2??? I've started on my winter build.. Currently have foam cut for the center sections sides and spoons for eight 29" boats. With the 34" to be started next. Not certain how many I'll build of these. After that, two 47" will be started up for gas. Think I need more pink foam!
Oh yea, one each of the 29" and 34" will be given to CMB club for the 2008 Would Outboard Tunnel Champs raffle.. If you were wondering why I'm building so many at once!
#31
ORIGINAL: ob nut
You have Gmail [8D] [8D] [8D] [8D]
OB PM sent to you..
OB PM sent to you..
I suppose the plans are V1. The main change for the V2 is recontouring the top of the sponsons. I suppose it's time to make the changes on the plans.
JD
#32
ORIGINAL: Jerry Dunlap
JD
JD
Still have that TS2 WOF needing the spoon repair.. Hope to get to that after the build! Still will do the website on the repair!
