AMPS hulls & outboards pics & tips {Agnew Model Propulsion Systems}
RE: AMPS hulls & outboards pics& tips
ORIGINAL: STEVE MARSHALL
Here is a link to the zenoah outboard bottom end.
http://ovalexpressracing.com/hardware.html
i have a problem with the spedo cable drives that are tilted so far that they dont look like an outboard motor. but i guess it really doesent matter as i couldent aford the beast if i found it. here is one really nice atempt but cant seam to find the builder. bill payne
ORIGINAL: gas pump bill
RE: AMPS hulls & outboards pics & tips international hobbies
here is a dummy outboard motor that i just got . now all we nead to do is build a drive train install a big motor. and and and . dream on
1967brutus (07-15-2023)
#31
has any one found out how to get the cowling rem project off the ground yet? just got a new boat that looks like the baja. its the prinzess by robbi. i have had the robbi motor for over 20 years. now i got the package. the boat is not built yet it was new in the box. i included a picture of a boat thats not mine just so you could see one finished with a robbi motor on it. the orange one is mine. i know its not an AMPS. but its still neat . please forgive me. bill payne
#32
#33
the prinzess and the baja apear to be scale versions of the GLASTRON GT 150 nobody is building a sport outboard boat . all of the posabilities are for raceing boats. i like electric boats but i dont race. look at all of the interest in all the old glastron boats. on the web. here is the robbe motor and a fiew other their all electric except for the big dummy and the AMPS motor.
#34
#35
WOW THATS THE SECOND ENGINE YOUVE SHOWN THIS WEEK WITH AN AMPS/ ZENOAH COMBO. THE FUTURE IS LOOKING FOR OUTBOARDS, BUT GIVEN THE PRICE OF GASOLINE MABY WE NEAD TO BE DEVELOPEING AN ENGINE THAT RUNS ON JACK DANIELS. WHERE CAN WE GET SOME TECKS ON THESE ENGINES?
#36
#38
is there a web sight for the mfg of that foot.? it looks pretty nice.
#39
FL
RE: AMPS hulls & outboards pics & tips {Agnew Model Propulsion Systems}
Does anyone have the build sheet / or knowledge for the AMPS Seebold hull? (the enclosed canopy type) I've had this hull since the 80's and would like to get her in the water. However, It appears that the back under side of the transom would have to be ground or cut back in order for the motor to be mounted. Is this right? HELP!
#40
ORIGINAL: 4square
#41
#42
FL
Ok, here's the pictures, It just looks like the motor needs to be attached with a spacer or the bottom of the boat needs to be trimmed, I purchased this boat from someone that mounted a K&B to it with an adjustable mounting plate. There is a hole in the transom where at one time a previous owner mounted or tried to mount the adj. trim bracket. Any suggestions guys?
/Users/williamladue/Desktop/Seebold transome.jpg
/Users/williamladue/Desktop/Seebold full.jpg
#43
FL
ORIGINAL: 4square
#44
ORIGINAL: 4square
I must not be uploading these pics correctly??javascript:void(AddText('[\&o]',''))
ORIGINAL: 4square
#45
ORIGINAL: 4square
ORIGINAL: 4square
#46
ORIGINAL: rcollector
#47
Yes, you just need to cut a half circle shaped notch in the boat just enough to clear the engine. You will also need to find an AMPS trim unit for your engine, or devise a way to adjust it manually.
That is a later model boat, probably one of the last they made. I have not seen a lot of them. The ones I have seen all had plain cable drive K&B's on them.
It is funny how there is so few people around with much information on these boats and motors now. I know quite a bit about International Hobbies boats and AMPS outboards and outdrives mostly because I have collected quite a few along with many spare parts for them. 5-7 years ago the people I got a lot of my engines and parts from seemed to know enerything about these but I guess they have lost interest in this hobby. They are not here to answer questions and I have had no luck contacting any of them. Those guys are out there somewhere , I just don't know where. They are probably just busy with other things these days.
#48
#49
ORIGINAL: 4square
ORIGINAL: 4square
#50
Here are some my boats. That was the white Budlight tunnels first and only run. I had decals made for it. I see someone else has posted some pictures of my toys. I guess I'm famous. ha ha ha
