Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
OPS 90 tuning help needed
Reply
Old 04-02-2008, 09:15 AM
fast9
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default OPS 90 tuning help needed
I have a used OPS 90 that I had to put a new piston /sleeve into. I just started it for the first time and it starts right up but then wants to kick over and run backwards. Causes/ solutions for this? I have 30% fuel in it for now and a medium heat glow plug. If the timing in the motor has been changed I am not aware of it.
fast9 is offline
Old 04-02-2008, 11:38 AM
piper_chuck
My Feedback: (12)
piper_chuck's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: OPS 90 tuning help needed
Are you using 12 or 24 volts to start it? If 12, consider switching to 24. On the big block engines, 12 volts aren't enough to overcome the compression, especially with a new piston/liner, and turn the engine at a good starting speed.
piper_chuck is offline
Old 04-02-2008, 12:03 PM
glennb2006
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As above plus:
Is the backplate and disc back in the same place it came from?
Also, have you altered head shims at all to alter compression?
Glenn
glennb2006 is offline
Old 04-02-2008, 04:28 PM
fast9
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I do have the 24 volt starter and it turns it well. It will start and run the proper direction for a few seconds and then stumble and reverse on its own. My disc opening begins to appear about 1/8" after the piston passes bottom dead center. I think this is correct? I reassembled using the head shims it came with(used). I am not sure about the thickness/number of the original head shims.
fast9 is offline
Contact Us Archive Advertising Cookie Policy
